  • Replies 112
yeah, i have an fcon pro v at home gathering dust!! came with the car, impossible to tune in melbourne.
Which really sucks coz they are a fantastic ecu, 32x32 mappings and heaps of features.... had to downgrade to a powerfc :D
Edited by MerlinTheHapyPig
Guest Mashrock
BD4s is the only licensed tuner in Australia.
CRD borrows the software from BD4s when they tune.
ah i knew it was in some mess like that.
who is actually good for tuning these computers??
as there is no way i'm putting in a power fc.
and how does this guy access his fcon files off the computer? can i link it to a laptop etc??
needs to know.
actually, without getting into some sort of argument here on powerfc vs other ecu's
Im not such a fan of powerfc's either, whilst they have their advantages in being a plug-in replacement ecu, they also aren't very flexible. and only have 20x20 mapping... (compared with wolf 3d v4 for example which has 16 load points and rpm points every 125rpm (which between 0-8000rpm equates to 64 points eg. 16x64 point mapping...)
Also i don't think power fc's can control additional injectors, thermofans, aux outputs, etc...
BD4s aren't too bad price and they are pretty proficient tuners (they also do other ones eg PFC). My brother's car came ex-Japan with an FConV which we got Yoshi to tune up.
Only reasons we switched to a PFC:
- BD4s is too far from us
- Piggyback vs standalone (plus someone stole the FCon :( )
Apples and oranges comparison. The Power FC uses the AFM as its primary load source, so it has very fast and accurate details on the actual airflow going into the engine. The Wolf uses a MAP sensor as its primary load source, which of course is useless once the max boost is achieved and held. So it NEEDS more loads points to make up for its deficiency in load sensing.
Looking at it another way, the Power FC arguably has more USEABLE load points. Because the AFM is showing changes in airflow while the MAP sensor is showing no change in manifold pressure. All the Wolf has is RPM changes, that’s one dimensional tuning. If max boost is achieved at 5,000 rpm, it could easily end up with only 20 X 1 (= 20) load points between 5,000 and 8,500 rpm. Compared to the Power FC with 6 X 6 (= 36) load points.
Use one of the Datalogit outputs to control the thermo fan, and other items if necessary (eg; we control the intercooler spray)
Much more efficient (more power, better economy) to run the right sized injectors, than band aid in a separate fuel source. It could be argued that the PowerFC runs larger injectors so much better than the other (similarly priced) ECU’s and that’s why they have to have extra injector drivers.
:( cheers :dry:
ah, wondered about aux outputs on power fc, because never seen it being used, thanks for clearing that up...
wolf3d can be set up to use either MAP / MAF / TPS for load reference. (actually you can use MAP as primary sensor, and MAF as transient sensor to detect fast changes in load)
now looking at MAP and TPS they don't operate on a wide scale. so when you floor it TPS will be the max voltage it can show and MAP will also do the same when you reach target boost. so from that point onwards your map resolution goes from say 20x20 or 30x30 to 30x1 or 20x1 as you are only showing increase in map points by the rpm increasing. configurable or not thats the operation, which lacks the resolution of th airflow meter equivalent.
with an airflow meter setup the airflow meter "load" or signal is always increasing as more and more air is being ingested by the engine.
so if the wolf (or XYZ ecu) use MAP and/or TPS then they are no worse off than each other and don't provide a better method. the best being airflow meter and measuring the air directly. the rest appear to be workarounds or bandaids to work around the age old "airflow meters are a restriction".
if its a restriction get a bigger one, if its too small, get two
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
