We all know it's the best way to waste time since the internets - but there's only so many times you can look at your house. What's the best thing you've found so far?
Here's some to get you started...
B2s being serviced at Edwards AFB
Tha bridge is owt! - missing piece in the old Florida Keys highway. Just like in True Lies
Cars on the hairpin at the Nurburgring
Carriers at the shipyards in Newport, Rhode Island
Anyone else have something good to show?
PS: search for Davis-Monthan AFB - Cool
https://www.sau.com.au/forums/topic/111328-google-earth/
  • Replies 82
wow. never even thought of using it like that...probably because i dont know how to use it properly!
but i found my house, my work, and some other local big things....but i'd say there is an easier way to do it than following the freeway all the way from the city, taking the exit i take and searching from there.....but thats how i had to do it :D
followed the whole ring road to find my work. lol
https://www.sau.com.au/forums/topic/111328-google-earth/#findComment-2052923
Well regardless of how cool all that is i found my banana parked out front of a friends house :D
It is a little hard to see but it's there!!!
well if i could find my street i would maybe see my car in the drive way but thats cools!
https://www.sau.com.au/forums/topic/111328-google-earth/#findComment-2053108
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
