We all know it's the best way to waste time since the internets - but there's only so many times you can look at your house. What's the best thing you've found so far?
Here's some to get you started...
B2s being serviced at Edwards AFB
Tha bridge is owt! - missing piece in the old Florida Keys highway. Just like in True Lies
Cars on the hairpin at the Nurburgring
Carriers at the shipyards in Newport, Rhode Island
Anyone else have something good to show?
PS: search for Davis-Monthan AFB - Cool
https://www.sau.com.au/forums/topic/111328-google-earth/
  • Replies 82
wow. never even thought of using it like that...probably because i dont know how to use it properly!
but i found my house, my work, and some other local big things....but i'd say there is an easier way to do it than following the freeway all the way from the city, taking the exit i take and searching from there.....but thats how i had to do it :D
followed the whole ring road to find my work. lol
https://www.sau.com.au/forums/topic/111328-google-earth/#findComment-2052923
Well regardless of how cool all that is i found my banana parked out front of a friends house :D
It is a little hard to see but it's there!!!
well if i could find my street i would maybe see my car in the drive way but thats cools!
https://www.sau.com.au/forums/topic/111328-google-earth/#findComment-2053108
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
