  • Replies 234
So if I were to get the Nismo injectors (was leaning towards these anyway) are they a straight fit into the stock fuel rail? I've had a brief look around for an aftermarket fuel rail (HKS, Sard, GReddy) and there doesn't seem to be one for an RB25DET. Also would it be essential/recommended to uprgade the AFM with the injectors? Just trying to see how much I need to buy before I get the Emanage installed so I can do it all in one hit. I've already done the fuel pump and a Nismo fuel pressure regulator is on the way.
"Five days on an all sprout diet with a wall papering video and a crochet magazine and we've all turned into crazies!"
thanks for your reply man.my car's coil pack already all ****ed up by that.now I looking for the coil pack.be careful when you do it......good luck
  • 3 weeks later...
Does the greddy e manage with profec e01 controller monitor knock?
Is it possible to get rid of the speed limit and change the rev limit using the emanage?
Is it much harder to install on a rb20det? Lots of wire puzzling?
What optional harnasses do I need using e manage with profec e01 on rb20det besides the normal ignition and injector harnasses to do all necessary?
Seem not to find real answers on these questions in the thread. I hope I am not asking things wich are already explained.
  • 1 month later...
OK, so after almost a year of having the GReddy Emanage lying around accumulating cobwebs and dust, I finally got it installed yesterday and tuned. The tuner that I had chosen had no experience with the Emanage b4 but was keen to give it a go. But really, the Emanage is not that hard to tune or install when you have the harness kit.
Initially, with the following mods:
- Apexi pod filter
- Trust R-SPL FMIC
- Blitz SBC idIII
- MV Stage 1 shift kit
- HKS split dump pipe
- Blitz 3' front pipe
- 3' Hi-flow Cat
- Blitz 3' NUR spec exhaust
- Bosch 040 fuel pump
- BP Ultimate fuel
- Bald Hankook Ventus K104 tyres
The line pulled 148.3 rwkw with 10psi of boost. Now, after installing the eManage and a few hours later 198.4 rwkw was achieved with 12psi of boost. The turbo is still stock and so are the coils. The plugs haven't been changed in about 12 months but are NGK platinums with the standard gap of 1.1 (I think).
That's the good part of the story!
A couple of things that I noticed while the car was going through its last couple of runs was that towards the end of each run little puffs of black smoke started farting out of the exhaust. I was told that this was because the plugs needed to be changed and that I should shorten their gaps.
Another problem occured when the car was idling and the kick panel was being placed back into position. As pressure was applied to the kick panel onto the ecu, the engine would turn off. I was told that it was something to do with the wiring in the harness.
Finally, the last problem was realised a little while later when I had left the tuners. The car seems to want to change gears at higher revs which is really a kick in the back. I can induce a shift by fully, not partially, backing off the accelerater at a reasonable point. Now even with overdrive on fourth gear will only engage when travelling at 100 kph. Even at 60-80 kph and backing off the throttle, third will be the highest gear selected. Also, when the car is warm and the gear is put into neutral, revs will drop to 500rpm and start hunting up and down. It also happens when the car is started when warm.
So as you can read there has been a few positives and negatives to come out of my experience with the GReddy Emanage. Fingers crossed that these problems are not permanent and that are fixable.
If anyone, DAN666 in particular, can shed some light on these problems, could you please reply to this post. I'm going to check to see whether the tuner had missed something myself with a PC 2morrow.
wouldn't the car wanting to change gears at higher revs be to do with the shift kit?
No, the problem is not related to the shift kit as this was done b4 the tune and everything was fine. Its just not going into 4th gear unless I'm at 100kph and back off the throttle.
I'm just curious to know what was done on the Emanage to have this effect on the shifts. The Emanage only intercepts Air/Fuel and Ignition timing. Would changing the ignition timing affect shift points?
OK since the harness plugs into the ecu loom and also the ecu, maybe signals required for gear changes are getting screwed with before being passed to the ecu. And since the engine would cut out when pressure was applied to the harness then the wiring within the harness must be screwed. I may have just answered my own Q. :lol: Keep the suggestions coming in though!
Most likely due to the Emanage changing the TPS signal. Shift points are usually shift event vs TPS vs road speed. ie at 100% throttle the car will change gear 1st to 2nd at say 55km/hr. Although I cant really see any reason why they would have changed TPS signal.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
