  • Replies 89
Posted Images
marlin i will do you a deal as it sounds like you the GTRs. You fly to sydney and i will supply the tickets for you and a friend for the day. Ring me when you are ready
Theo
Wicked Theo! Thanks mate!
I'm checking the flights now! I'll call you when I've booked them.... thanks again man.
I was planning to go to Sydney on the 25th for the Origin, maybe I'll go a little earlier and make a time of it!
It'll also depend on if I'm sick of looking at GTR's after sitting in the crazy seat of the 34 at Targa Tas for 6 days this month!
Edited by Marlin
Congrats Theo. Good to see a 26 pushed hard instead of going the 3lt route. I gave the red stagea I bought from you to the missus. She loves it. Got a 260 for myself and ran a 12.5. Stock apart from pfc and other little bits.
Keep up the good work.
Ill come to Sydney to see you run, you pay for the flights (Im in Darwin) and Ill buy the tickets. :D
Best of luck.
Edited by RBNT
Theo, i dont care much if you ran on fedrals, MTs, Nittos, or mohawk re-treads. 9.3 is a pretty good achievement. well done. i am not a big drag fan myself but may just come out to see this theo vs mark run happen at WSID. :P
Oh, so you mean I can be competitive in my stock GTS-t? That would be great, then I can mouth off on all the forums about it.... errr hang on
But you don't have a stock GTSt, Chris. You have a tubbed, caged, slicked bad-boy being built by Wild1 in Wollongong.
Can't wait to see that run hard - show these 4wd guys how it's done!
Adrian
Adrian
has a street rwd car ran 9's yet......ahh thats right....no....still waiting to be shown how its done.....
Disclaimer: no dolphins were harmed in registering this post
Anyhow enough dribble...back on topic....
I dont give a flying fu(k if Theo ran his time on Bob Jane "All Rounder's" its still a great time and one to be proud of. Its always good to run a P.B. Well done and would be good to see it bettered and backed up at an official ANDRA record setting event.
Disclaimer: no baby fur seals were clubbed during this post
Edited by DiRTgarage
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
