i dont take it for granted but damn i always thought mx5 were slow fwd cars for hairdressers
Err they are (except for the fwd part)! Well non-turbo ones anyway.
Though the turbo SE is still only a 15 second car. He must have had some work done to it.
Edited by merlin6014
  • Replies 48
i was out driving last night in the 33 (exhaust, pod, intercooler, 12psi) and an mx5 came up beside me, guy had the roof down and looked over at me. thought, ok, lets go. anyway this guy took off, got a good lead on me and i couldn't bring him back in.
i thought these things were slow fwd cars?? how did this one go so well
WTF were you doing racing people on the streets? You're a DI(KHEAD.
Sounds like there's a lot of guys here with their heads nicely buried in the sand.
For the guys who think the mx5 is a 'hairdresser's' car... Get out and drive one, your opinion will change.
020R33, I think you should challenge the guy to a track race. Obviously it'll depend on what you've done to your car. But, with everything you've said about your car, and the 177kw you've got in your skyline(which looks nice by the way)... I'd be backing the SE mx5 to give you another a$$ kicking. It'd be a pleasure to watch as well.
Don't get me wrong guys, I love Skylines, the R32 GTR being me favourite, but if you're going to open your mouth about a car, save yourself the embarrassment and do some research first.
:mage:
mick
Here's s video, in car cam, of my MX-5 (1.8 NON TURBO, street tyres) vs. WRX STi 2-door:
http://www.jdmyard.com/jdmyard_2006/images...inmx5/canto.mov
PS: I own both an MX-5 and an R32 GT-R. I love them both for very different reasons. To cut it short, the GT-R for brute power, the MX-5 for it's amazing handling.
Edited by justinfox
Nice one. I almost grabbed an MX-5 once but went with a Laser Lynx instead. Same engine but front wheel drive and a massive hatch area so really useful, plus it's heaps of fun to drive once I sorted the suspension out a bit and then setup oxygen injection for a neat 7.0s 0-100 performance. I always thought the MX-5 could do with a little extra punch but it's easy to overpower the chassis and then they just get difficult to drive. With a little suspension work they are lethally quick on a racetrack due to weight and balance. They do of course suffer from the low power so will not win the drag or on a long straight, but that low power means you can floor it in most situations and not light the rears. Makes for great confidence on the track and often that is as important as power.
Anyway you reckon you are an experienced fast car driver, but don't have a clue what else is out there. That is just ignorant and dumb. I also don't consider your previous cars fast, not even a little bit.
All that said though, some very basic improvements to a GTS25t will entirely destroy the MX-5 (and an S2000 which I consider a more worthy challenge) on circuit, especially if you can actually steer, but that's the rub isn't it? As asked before, can you actually drive? And why the hell are you racing on the streets? Tool.
And for the MX-5 guys coming on to try to beat things up, welcome but remember...
Teh GTR can Nevah Lose!!!!
bye bye thread.
If you want to get involved in street racing, that's your business, but don't come on here creating threads about it.
If you're interested in specs of particular vehicles, feel free to start a thread to that effect.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
