  • Replies 68
Hi Guys,
Sorry for the late reply but been very busy trying to organise the move etc.
Firstly thanks to everyone for the help and support.
Roy, Dont stress mate the stubby holder is safe and sound.
In regards to the dyno setup, we will be running the usual 2-3 runs, monitering boost and afr, with printouts supplied.
There may be a opportunity to do some tuning depending on numbers etc.
We are keen to see as bigger range of cars as possible so pass the invites on to owners outside of this forum.
We will be equipped to remove front shafts on gtr's, but unfortunately other 4wd's will be unable to run.
FWD's are no problem.
rchoo, Sorry mate not technically open till next week, but if you want to discuss any mods further dont hesitate to call my mobile below.
As we dont have a land phone line installed yet contact details are as follows:
Racingline Motorsports.
15 Bricker st, Cheltenham
0410697349.
cheers.
Nigel.
Hi Guys,
0410697349.
cheers.
Nigel.
Thars cool mate.. will catch ya on the day.. cheers.
Another B'day on the 13th of May... hmmm... Might come down if I can - my R33 is pretty much stock, but my housemate wants to find out what his Z31 is putting out (since he blew it up on a SAU GOR cruise some time ago & has only recently got it running again properly)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
