looking for a guy that can come to my house & replace the studs on the manifold..
i know anyone can do it but what im worried about is, if one snaps and im screwed,
so the person who is replacing them would have to have the facilities to get a snapped stud out just in case
i have already been quoted $160 from a guy out in horsby to get take out and replace all of them..
anyone know off or used someone before???
thanks guys
i was lucky, when mine snapped, i was taking the head off anyway and getting it serviced, so i got mine replaced then
and again i went all new studs and nuts when putting the new one, but exhaust guy replaced them for me..
there is like $40 worth of studs in there, so $120 for that prick of a job is pretty good.
Doesn't always work, but often helps: spray heaps of WD40, RP7 or some similar water-displacing stuff some time before you start, then a little bit more just as you begin. Helps ease the stranglehold of the rust making the nuts stick to the studs...
or your other option is
- lots of wd40 the night before you attack them
- get a set of eazy-outs
- spring loaded center punch
- small compact drill or air drill (recommended)
so if you break em you can still finish the job.
i think its a good idea to change all of them while you can.
Make sure everything is cold, plenty of WD and give it a go yourself. If you snap a stud just keep going. At the end IF you have snapped a stud or two call out the experts to remove...or you can be an absolute hack like me and just screw the snapped stuf further in and put one in over the back/top of it....after all it is only an RB20. :D
Why spend $100 on window dressing an engine you can buy for $600 :D (LOL i will never try to remove a snapped stud again)
The thread man did what i needed (two studs helicoiled) for very cheap compared to others i called, and i needed him for one last bastard bolt and he came around and did it at late notice for cheap too, so whatever he charges would be about right he isnt the type to rip off thats for sure :) tell him u found him from guy with the red skyline (me)
hmm I was lucky when I snapped 2 there was enough thread to get 2 nuts over it and remove as normal.....just have the number on standby if it all goes bad.....but I wouldn't try the helicoil myself....it will probably work but if you snap the helicoil you are *rooted*
Duncan, i think you mean if you snap an ezi out, (not a helicoil) in the hole then u are properly screwed :D
the helicoil is just a new thread they screw into thread they make in the drilled out hole, an ezi out is the stud removal tool which is reverse threaded and u screw into a hole in the broken stud and turn anti clockwise to grab the stud and unscrew it.
using the ezi out is worrying and i wasnt prepared to use on on my head alone either :D
Dude $160 is dirt cheap.
I was quoted $450 as it is a prick of a job that requires removing the turbo and takes a few hours to do.
Id be taking that deal if I was you.
i plan on removing everything for him, turbo, manifold.. everything
ive taken the turbo off lots of times.. lol
i can remove everything in an hour easy
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
