Thats ok, if you still cant find it the mounting points are on the rear wishbones by memmory. Its hard to picture where is would go because the swaybar link is a stright cylindrical piece of metal inlike most other links, you need nuts either side that go through the wishbone in the rear . But if you get whiteline they change the design and you need to buy there links to make it suit, its a lot better than the stock rear sway bar, because the design changes the whole way the sway bar looks and fits.
  • 1 month later...
if your after info on GTS4 box check this:
http://www.skylinesaustralia.com/forums/topic/370991-r33-gts4-na-box-to-handle-250kwatw/page__p__5924403__fromsearch__1#entry5924403
will give you some solid info ;)
gtst, gtr, stagea, gts4 all have the same subframe so most bits n pieces are interchangeble.
1st 2nd is definately shorter, 3rd is slighty shorter and 4th and 5th pretty much same, feels absolutely fine apart from the common weak synchro issues but soon as i used some redline lw sp that fixed it up pretty good.
hey guys, rather then starting new thread...
Im just in the process of putting r33 gts4 runing gear into a gtst shell. I know its easier to start off with RWD components, but I already have these in the shed, so...
Ive just removed the RWD sump and started to remove the gts4 sump, the bolts are much largeron gts4 ? Can i just bolt up the rwd sump to the awd block and which bolts ?
Also, if i just drop the front driveshaft, can i drive the car aroud safely in RWD ?
Can I use the gtst tailshaft and diff ?
Anything else to look out for ?
Help greatly appreciated. thanks guys
no one has a clue because no one has done it......main reason because its pointless....
Thanks for your input :)
sumps seem to line up perfectly, just took them off, havent had a chance to bolt it up yet :)
Now just need to confirm if i can run the gearbox with the front driveshaft dropped off, without any issues ?
Edited by KISIN
I have rebuilt GTS-4's engines, diffs, gearboxes BLA BLA and how did you get them to line up????????????????
They are no where near the same shape as the block? The GTS-4\GTR block petrudes out where the diff is and it has 4 or 5 different styles bolts where the RWD is just rectangle and uses 30 of the same bolts.......
They will fit but they are not the same 270CC like the NA ones they are about 370CC
  • 1 month later...
  • 1 year later...
I'm thinking of getting a gts4 , what's some basic/cheap things that I could do to improve it's performance ??
Full service of everything, wider/better tyres, suspension, brakes.
Build driving experience, get full license.
Sell it and get whatever you want.
If by that stage you've done all that stuff and had it for three years and still want to sell it... Well sir you obviously don't love your car
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
