well i have a R34 with factory Nismo crap exhaust.. atm the sport function is closed.
i flick the switch and u can hear it attempting to move, but it dont move at all.. ive even taken the spring off both the exhaust + actuator and cant even pull it with plyers to open/close..
i've WD40'd it.. no change.. ideas until i can afford a full exhaust /tip
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/
Yeah apparently they pretty much all do this after a bit. I've got a cat back exhaust going pretty cheap if you want. Send me a pm.
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2111954
thanks for offer dude :(
im just broke atm.. just bought the car and got my cf bonnet on it.. got coils on the way 1st since the car drives like a boat atm.. can barely feel the road.. i hate it.. i want my no-suspension feel back :(
once i get to that point.. ill see if i go FMIC or exhaust 1st :(
found solution:
step 1) take off the rear muffler
step 2)proceed to bash with hammer until it moves, if it doesnt move, break the muffler so have the exhaust pointing out the back of the car, not at the rubber on ur wheel...
step 3) admire your hard work :)
god i love being dodgy :)
Edited by illusiVe
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2112161
  • 1 month later...
  • 1 month later...
Thanks for the tip mate. I've let it soak up in wd40 and i'll give it a shot tomorrow morning.
Say guys, how's the nismo exhaust in terms of restriction? I'm just trying to sort out priorities for modifications right now and wondering if i'm being bottlenecked substantially by the exhaust and if it's worth me spending another 1k on a turbo back system (or another cat back for that matter).
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386112
For memorie it is only 2.5 inch so a 3inch will still be a gain and the
rear muffler is still a bit of a restriction so yeah a , highter flowing cat back
will make a differance and frontand dump in one plus a 3inc cat
will make quite a substancial difference.
and will be stainless if you choose as opposed to mild steel
so it will have better heat dispersion properties.
hope this helps :)
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386129
Sweet that's very helpful.
Say does anyone know the diameter of the stock (non-nismo) r34 exhaust? and does anyone know if the exhaust control valve can be used on any aftermarket exhaust systems? Reason I ask is, i unfortunately live across the road from the road transport authority where they often set up defect stations ... they've been wanting me badly for a long time now :)
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386137
it is still2.5 inch for stockbut you have ecv and also higher flowing muffler on the nismo exhaust, and you carnt really adapt it to any other
exhaust ,apexi to make a ecv but is not cheap and does not drop by many db,s and i think the epa would test with it wide open anyway so not really any point with having it, just make sure if you get an aftermarket system that you get one with a middle muffler as opposed to say a blitz that is just a hot dog, and you shouldbe safe with that.
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386261
best thing to do is get a cheap old throttle body (as thats practically what it is.. drill some holes thru it so air can ALWAYS get thru, then hook the spring up, press the valve button to make sure it can open/close. with the strength of the spring.. and ya done :P
very stealthy too... plus its factory so they cant fk u for it.. although u may want a TIP which helps the stock look :)
total cost $50 for 3" throttle body $20 for the weld in of it.. 2 hours of work.. $50 of beer while working on it :D
Edited by illusiVe
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386578
hope this helps :P
What? How does the heat dispersion properties of a metal improve it's function as an exhaust? If I remember right you want the heat to stay inside the exhaust to improve the gas flow hence why you coat exhaust manifolds with ceramic.
https://www.sau.com.au/forums/topic/114674-nismo-exhaust-q/#findComment-2386670
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
