Can anyone tell me the weight of a 40mm aftermarket radiator, say from ARE, PWR or Race Radiator comlplete with coolant vs the std radiator complete with coolant???
I think im marginal for cooling with my new bar...so if the aftermarket jobbie will weight more then that will basically make up my mind
Also, does anyone know the respective weights of the RB20DET 5 spd, R32 GTR 5 spd and R33 GTS25t 5 spd?
https://www.sau.com.au/forums/topic/115067-a-silly-radiator-gearbox-question/
it hardly weighs anything different.
the ally radiator from Race (same as mine) is very light.
Its holds a bit more, but then thats a couple KG's if your lucky
GTR 5-speed, more than RB25 5-speed (obviously)
Its a fair bit heavier.
One person can move the RB20 on thier own, normally takes 2 people for RB25 box, so fair difference
rb20 gearbox = light as not a problem to lift (about same as a sr box)
rb25 gearbox = can be lifted by one person.. best for 2 people to do so as im 6ft n 110ish kg and i struggled to carry it a distance but how ever did so
gtr box = couldnt tell ya never had to lift one
even the stock rb20det radiator is very light without water in it.. I'd estimate about 3kg. It's not something where weight saving is going to be an issue.
just make sure you don't use heavy water in there or its all over :P
LOL...but my concern is at the moment my cooling is marginal. If a new radiator is going to be heavier then im happy to keep the car the way it is with the std radiator...but if there isnt going to be more weight then ill try and grab an alloy cooler in the next few weeks, will se how it all goes.
Ditto the gearbox, my current gearbox seems happy enough, but it is the most likely part on my car to break next so want to have a plan for when it dies...and no way i want to throw 20kgs at my car, if thats what the difference is...its not like i have big torque and 300rwkws which will kill the RB20 box.
What is the point in the aftermarket radiator if it doesnt hold a greater capacity of coolant (and hence weigh more). It is a heat exchanger after all, greater the thermal capacity the better. This is assuming the difference in weight of the alum and plastics are neg.
Edited by DCIEVE
The point i would think is not too have more weight or internal volume...but greater surface area does improve effeciency...and i would want one for improved effeciency/heat transfer.
Im just worried about putting too big a radiator in my car at great expense and additional weight...ignore the numbers biut an example is why have 5kw cooling capacity when i only need 2kws?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
