hi there,
this mod is suitable for rb20det, rb20de, rb25de and det(as long as you have an ingnitor pack on the cam cover) can be done for series 2 rb25s but you will require an ingnitor pack.
i have a cheeper alternative for all you people out there who keep losing coils and dont want to fork out big $$ for spitfire coils.
what you will require:
6 spark plug leads that are a suitable length to reach to where ever you decide to mount the wasted spark setup. i used champion steel ingition leads part number CH6106S for a holden commodore vs&Vt 3.8ltr but i suggest you buy them individuly as you can get the lengths much better as i found 2 of them are a bit to long
the replacement coil pack is what i was told is a buick(holden) tridon part number TIC032
side cutters,
soildering iron and solider, or crimpers and the correct crimping bits to clip on to the coil pack.
heat shrink
and between 1-2hrs to do.
step 1:remove coils and coil loom from the car. and decide where you want to mount the coils.
2: strip the coverings off the wiring so you can see where and what wire each one does.
3: lable the pink wires so you know what wire is for each coil. then cut off near the plug
4: for r32s you will need to make sure you dont cut off the ground wires from the ingnitor pack(7 wires) to the other small plug(3 wires) next to it. r33 has (6wires and 2wires so there is no ground wires to deal with)
5: you will need the white power wire from the 3 or 2wire plug as that is the power wire for the coil pack.
6. group together the pink wires in to 3 sets. 1 and 6, 2 and 5, 3 and 4.
7: i suggest you lable the front of the coil pack as you attach the wires to the coil pack as to save on any confusion later on.
8: attach the white wires to the pins showen on the pic. it doesnt matter what side of pins you use as long as all the white are on 1 side and pink are on the other side.
9. mount the coil pack in your engine bay. make sure that the pins on the back are not touching anything. i folded mine down and put shrink wrap over them just to be safe.
10: put the spark plug leads on the spark plugs and the coil pack in the correct order and plug in ingnitor pack.
11: if your car had dropped a coil then you should reset your ecu. but reset it anyway to be on the safe side.
12: start your car. if it doesnt start check that the leads are on the right plugs as its easy to accidently put (3 and 4) on (1 and 6). if its r32 check that you grounded the ground wire.
otherwise just check that you did wire everything up correctly.
i will try and get walk through pics if i do the conversoin again :( hope this helps
https://www.sau.com.au/forums/topic/115690-wasted-spark-ingnition/
  • 2 months later...
  • Replies 109
Posted Images
Hi,
I have an RB25DET series 2 in my car (ignitor in the coils)
I got an R32 Ignitor, just wondering if you can confirm how I need to wire this up?
I presume I should run the power from the R33 loom to the Buick coils, the R33 gnd to the gnd on the coil side of the ignitor, cyl 1,2,3,4,5 and 6 wires on the R33 loom, to the corrisponding wires on the ignitor.
Hi there.
strip off the inuslation off your coil pack loom and you should see what is happening. dont cut the plugs till you have labled what wires go to what spark plug. take photos as you go incase you forget somthing.
pink is the power so you put them on one side as i have. white is signal from the ecu to spark.
you dont need any grounds for the coil pack. as your using r33 coil pack loom you dont need to worry about a grounding loop that r32s have as they have an extra wire on the r32 ingnitor and on the other little plug has 3wires instead of the 2 that r33 have.
Have you given any thought to the resistance of the coils being different, which will affect the dwell period as well the current limiting. Electronic ignition systems are capable of dwell extension and also current limiting. The resistance of the coil will vary both things.
Edited by kjb_r33
no, i am just following what others have been doing. this set up must work as it is used on 90% of the top rb powerd drift cars in NZ from what i was told by the guy who sells this as a made up kit.
i have some links to other websites with the info. this dus improve idle, acceleration and i found i got a little bit more fuel econamy and power.
http://www.dsd.co.nz/coils.htm
and the guy who sells the set up
http://gdz1la.kol.co.nz/prod01.htm
there is also guys who use mitsi VR4 coils and other kinda coils.
These have been done many times on skylines and they do work. Won't be expensive at all.
I actually have a link from r31 skylines.com where they install it into an rb20.
If you want, I actually have a coilpack and leads that I was going to use on my car, but I was given a set of splitfires for christmas. I'm not looking for much.
all you need for the series 2 swap is a coil pack and mb the coil loom. im not sure on the series 2 coil loom will plug up to the coil pack as i dont even know anybody with a series 2 engine.
my set up cost me $140 all up from memory. i probly could have done it a bit cheeper if i had bought leads seperatly. plus then they would all be the right length...
you will need an ignitor pack as the series 2 don't have them.
i was telling my mechanic mate about this and asking what other coils you could use. he said that the coils off a vt/vx commodore would be good, for some reason which i can't remember but will find out. but he also said that they have a built in ignitor which would make them good for series 2 r33's. i'm going to try to get a hold of a commodore coil pack and plug in the next few days to start working on a conversion and a how to.
yup the ingniton leads go on top of the spark plugs. makes changing spark plugs nice and easy especialy if you dont have the coil cover on.
im going to do the conversion on my mates r33 gtst in a couple of weekends. ill take some better pics hopfully this time from start to finish.
its the same as running your normal coil packs. except that 2 plugs fire at the same time. so the plugs will be doing 2wice the sparking they would with normal coil packs. the main idea of this is to get the coils away from the heat of the engine as that what kills the rb coil packs.
i have had people with series 2 rb25s pming me and they have almost got it sorted using a r32 coil pack. im just waiting to hear back from him about how it all went.
Having a quick read for the last 20-30mins, it seems that for series 2 rb25's I would need an ignition from either a r32 or r33 s1 with the r32 being the more favourable. So this means, I would need the wiring look I would presume? The one in which fires the coilpacks...
if i get this commodore setup going it will do away with the need for the ignitor pack as the commodore coils have the ignitor built in. also the good thing is that a full set of msd coils for a commodore are around $300, which is a lot cheaper than $900 for splitfire skyline coils.
but it is looking like it may be a week or 2 before i get a chance to have a try as i'm off to the test and tune day at willowbank this weekend.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
