How about hide and seek, game between the two teams of cars.
We get 15 to 25 cars on each team and have a co driver with a phone number to check wih the coordinators to track the cars and locations. Each car can move the hiding position only twice.
While the other cars go hunting.
We select an undisclosed area with just enough streets and hiding places. Enough for cars to seek each other. Something like corner of Round house freo. Or a light industrial area somewhere......
And we make the time limit for the other team to round up all competing cars.
The winning team gets the drinks from the other team ...or a general prize......
Just a thought guys and gals :)
al
  • 3 weeks later...
  • 3 weeks later...
Ok, posts for cruises are few & far between on here, but...................
any idea when the next sauwa cruise will be??????
Will have my car in the next couple of weeks & will deffo go to the next one (even if it is a while away), but even any other open cruises for meeting people, checking out their cars etc etc.
Cheers.
Joe - we plan to have one official SAUWA cruise a month.. alternating bewteen a sunday/bbq one and a night city one.... if you came to the meeting mr joe joe.... hahaha
hrm a monthly cruise would be great perhaps on monday nights :( at least is something to look foward to when the weekends over and back to work ;)
We have our night cruises on friday nights because we can run them later with less traffic and the day cruises are on sundays with BBQs
You guys are free to organise and advertise your own cruises on here if you want to run one on a monday night! :rant:
ahh i see :D bad news for me unless you run the friday night ones after 11:00 Pm ish and sunday day ones before 2pm haha
tis the only think that sucks about cooking industry working 6 days a week except monday night :(
ohwell
ok, so sauwa club cruises are once a month? which friday do you guys hold it? trying to find if you guys do a monthly cruise like silviawa.
We dont have a particular friday - its just when Dan has time to make one or there arent other events on
Seriously - feel free to organise your own cruise and advertise it. Read the cruise rules and guidlines for making a cruise. People will come!
  • 3 months later...
  • 4 weeks later...
You can start a new thread dude.
No point ending this one when its called "Ideas for our next cruise"
*Throws an idea up in the air..
How about every second Sunday we head down to the rivervale sunday session. "its not a cruise" but its an event and its on every sunday arvo, will get some people outa the computer room! + people can meet face to face.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
