BB - Hitman didn't tune my stock ECU - he tuned the SAFC2 which is in my car. The stock ECU has a lot of operating parameters as we all know - we couldn't wind up boost past 11psi as the car would cut out at 4.5K rpm.
sorry mate, silly me forgot about that. just when you said 'tune' and 'stock ecu' for my brain said re-map!
  • Replies 264
Posted Images
Good talking to you Joe :P
And thanks guys. :(
Links; he doesn't want to use your turbo It's not good enough, he replaces it with a "new" item! Bastard :P..
Hmm.. so flog off mine for 300.. pay for some of the intercooler.. hmm.. not bad.. not bad.. get an aftermarket ECU.. good $2500 upgrade + labour + tuning..
Satanic Im from brisbane/gold coast. Im not sure if its because I had that on holiday glow or something but the women in Sydney are far more willing I found when I was down there a month back.
But f**k driving in that place, what a joke. Better chemists up here however if you need vitamins or berocas hehe
Checked in the coin compartment above your right knee? I always forget I have money there!
??????? no not there, found 2 buttons instead - 1 gave me decent levels of boost, the other gave me ridiculous levels of boost. No coins there - I gather I dont have a coin-slot.
ross80: you must be doing something wrong! Last time I was on the Gold Coast, all I saw was "hi-beaming" everywhere!
Tangles: you're just special! Where can I get those buttons? I believe the $4.80 in my coin tray is a small price to pay for buttons :cheers:
Of course I am. LOL.
Im actually pretty sure you've got the same boost controller that I have! (Hybrid 2stage), plus yours has more kick than mine anyway! Now, my wife has a coinslot stashed somewhere, but hasnt dispensed anything to me for a while, all this talk of highbeams is driving me stiffly up the wall.
:D
anyways, on topic, Im pretty sure I'll be going Ball Bearing, not Bush
Dyno Graph is on my website... follow the link below.
Links; he doesn't want to use your turbo :cheers: It's not good enough, he replaces it with a "new" item!
PM me for more details if you want, Northern Beaches Performance has a few deals going on with Sliding Performance at the moment.
Just had a look at your webpage looks like a pretty good setup. Is it as easy to bolt on as the GCG one? Are both the oil and water lines used with the journal bearing setup?
Looking forward to seeing your results with the new injectors and ECU installed.
cheers
Until i see a back to back comparison against a GCG hiflow i wont hold my breath. at half the cost and journal bearing I can't see it being as good.
I am interested in installation routine to get it working and boost response
Just look at my dyno graph.... even though it's half the price and journal bearing, I'm telling you it is very comparable! I should really put my torque curve up :)
Nah, I'm not going to argue - my knowledge is not that great about turbos and I admit that. All I'll say is that I'm very happy with my pet snail and can't wait to feed it some steroids!
Installation is bolt on - provided all smaller fittings and all that are purchased, shouldn't take that long.
Thanks again Stan
The turbo's are straight bolt ins with only very small modifications required and that is to one oil line and banjo bolts/nuts which is very cheap to do and the following instructions will explain.
These modifications are required to assist in cooling and lubricating the journal bearing.
http://img62.imageshack.us/img62/6655/inst...inesandbanj.jpg
I am more than happy to answer any questions you may have.
Please email me at [email protected] or alternativly just pm me :)
hey i know i sound like a newb asking this, which i am but what is the difference between ball bearing and bush bearing? any spooling differences? which one has longer life?
slide: money is starting to build up... one more week i hope and i will be able to try out this thing.
stan: hey man, im guessing your hitting boostcut? maybe? dunno? hehhee
    • Physically, you'd expect it to turn the motor 11/8ths faster than a standard one, but I'm not sure of specifics
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
