  • Replies 70
Posted Images
Deca Accommodation - Fri 26 & Sat 27 May, It's all about the hats!!!
Where: Victoria Lake Holiday Park, 536 Wyndham Street, Shepparton, next to the Shell servo.
When: Fri 26 & Sat 27 May
oh wow, look at that!
Oh no you didn't!
  • 2 months later...
BUMP
These shirts will again be available at this next DECA (26 August).
I still have reserved shirts for:
Nate
Dezz
Justin (Kamikaze)
There are 14 left in stock in the following sizes:
S - 1
M - 6
L - 2
XL - 4
XXL - 1
Yell out now to reserve your shirt or come see me.
I will have them at the monthly meeting (15th) for people to buy/pick-up then, and then of course they will be at DECA.
Should be noted, these shirts are limited edition, once they are gone, no more will be made.
:laugh:
ooo didnt know 1 was reserved for me! dont know what size, but if possible hold a medium and large for me...probably medium depending on how small the make is....
i better reserve that last small for haley too please
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
