lol. steve.mad vids dude :D
No worries
i think il keep the wastegate venting atmos.. it just sounds tooo good
Yes, you really should get someone to drive it past you at full noise, its an angry, angry sound :)
Yes, it was by far the best RENEW's day we had, they had their sh!t together, we were on the track early and I did about 160 laps, a great day, well done RENEWS and SAU. TOP SHOW!
Im very happy with the 1.09 it was my goal for the day and I got there, I did crack a rotor I will post up some pics for a laugh! If any of the passangers were wondering what that shutter was, it was the rotor's I check twice but both times the crack was under the caliper. I drove home without using the brakes once, goto love that M7! Drove into UAS at 8.30am on Monday morning and drove out at 10am with DBA 4000 rotors, Im not sure if they will improve my times, but I can no longer say I have STD brakes and suspension, as I now have an upgrade, even if the upgrade was 7% the cost of the original Nissan part.
FYI $220 for DBA's $3300 GTR STD rotor.
Well done to all first timers, everyone drove hard but not stupid, and it shows with no broken cars or accidents, well done everyone top work, and I trust we will see you at the next day.
Pics of the old rotor???
Well done on cracking the 10's, and thanks again for the laps :P
  • Replies 513
Posted Images
I cracked my front right brake disk, I was very lucky it did not happen on the track otherwise both myself and the car could have ended in a big mess! I will take a photo and post it up.
Here are my pics guys..
Great day..>weather was good...not good for me as it was abit difficult getting the lighting right
i loved the s14 screaming past us, oh and T04GTR, your car sounds awesome too..GO SCREAMER! :D
the only flame shot i could get
more more at TRANSELITE
my youtube vid has updated.. no need to direct download..
Def need someone with a video camera out there next time.. it's so easy to compile it with either windows movie maker or adobe premiere..
Edited by Links
I've got a lot of video to edit and burn to DVD. I'll organise to send out discs to those who want them once it's ready. I'll post in here once it's ready to go.. It'll be relatively un-edited (no music and such) so you can play with it as you please.
Hey guys,
Thanks to all of you who came along on Sunday.
We are glad you all had such a top time. Was great to see so many first timers out there, and also a few girls as well. Good stuff.
RENEW is close to finalising the details for the Eastern Creek day. Keep an eye on threads here, and also, those that attended the OP and WP days, we will be sending you emails too..
Cheers,
Craig
RENEW Secretary.
James i hope you liked your ride, sorry it wasn't as quick as i took Liz around but she brings the best out in me, with the quote "man hit the ripples, your driving like a pussy!" with that i thought thats it if i go off who cares just as long as i scare Liz, but i didn't dammit.
hahahaha you were fully cut when i said that!
but at least you got fired up!
Im keen for a copy :nyaanyaa:
Not sure if this was mentioned previously but I noticed someone had an onboard camera.
Any one know who has this footage?
Yeah would've liked to see what times i did with you in the car, i reckon you were worth another sec or two for me!. Best flame ever Liz! :nyaanyaa:
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
