oil filter has been changed several times to eliminate it causing the problem. However, releif valve should be open if there is a restriction in that area.I seem to think that it maybe jammed closed and not operating at all ! I have taken it apart to check spring etc, found 2 shims under the retaining bolt, and also took aparta brand new N1 pump and found no shims ! they are only 1mm total thickness, harldy enough to change base oil pressure at idle by 65psi !
I have checked the spring rate, it is a linear spring and the same spring rate as a standard gtr 32 pump, the satndard pump i was comparing had 1 shim(0.5mm) the pump on the car which i am having problems with has 2 (1.0mm) and the brand new, unused N! pump had none !
Hence i dont think that this is the problem
I use a rule of thumb of 10 PSI per 1000RPM.
This 92PSI @ Idle sounds extreme.
Also when changing shim sizes, I have found on average for a pump this size (Pressure vs Volume) that as little as 0.010" can change the pressure 4PSI around the 100 mark.
Your releif valve could be just jammed shut?
>_<
ok... 92 pound is pretty normal.
my 200k old 32gtr runs:
cold start up. 6 bar
rev it abit goes up to 7.6bar
when the oil is at 80 degrees:
2.5 bar at idle 4bar by 3500 6bar @ 5000
its not a 253 mate.
thats some normal shiet, dont stresss
No that's not normal for an engine at idle and the oil at normal operating temp, as per the OP. For a stock oil pump and engine in good nick, an R32 GTR should have oil pressure of about 20psi at idle. The N1 oil pump has an increased spring rate on the relief valve to boost oil pressure, but at idle that should only give an increase of maybe 5psi at most, and certainly 92psi is way too much. Frankly I'm a little sceptical at such a high reading, esp at idle and would want to have it triple checked using a _calibrated_ gauge, but the cause is probably related to the relief valve and that needs to be checked.
SteveL, I would have to agree with you, as for checking the oil pressure, 3 guages have been used, all calibrated and all read as explained.92 psi at idle i believe is excessive, this is also at normal operating temperature ! Also, oil pressure doesnt change through out the rpm range as indicated by an increase in oil pump speed.I dont think that the relief vavle can hold such pressure when rpm increases, simple maths says, increase flow rate(pumps rpm) must be proportional to pressure head.Given the standard 10 psi per 1000 rpm, @ 6000 i would have approx 150 psi !, this is not the case, checked , re checked and checked again, oil pressure remains at an indicated 92 psi.
Its got me stumped
200
Have you checked the pressure with analog gauges or 3 standard nissan in dash units?
If you havent tried this, then get hold of a mechanical analog gauge, say 0 - 100 psig, see what happens.
You may have an electrical fault, sending the wrong current through the gauge. Because you said that it's at 95 pretty much all the time, it's like an alternator with it's current load when charging, kind of constant.???
Just a thought.
Glenn
Im pretty sure he did say 2 mechanical gauges and 1 electrical gauge...sounds like hes in a workshop or works for a workshop so im guessing you didnt try three std gauges? And im guessing they tried the same gauges on another car to make sure it wasnt reading 92psi...seriously what are the chances of three gauges all stuffing up at the same time?
There isnt some highly unlikely piece of shit or something that is blocking the gallery to the oil pressure sender feed and causing whatever amount of flow to equal 92psi? Just thinking outside the usual square here especially since the basics have been checked.
i have had excessive oil pressure before on an SR20 (in a GTI-R). pulled off oil filter, poked finger around in there, problem went away. dont know if that will help, but it helped me!
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
