last nite was at calder, nice night some tuff cars.. NOT MANY SKYLINES THOUGH
anyway cut the story short. There was a really neat looking r33 gts-t with a custom burgundy color, this car had some balls u could just tell by the way this thing was running. But whoever owned this car did not know how to drive it at all.... Just wanted to know if anyone had seen this car and what there thoughts were...
It was really disapointing to see a nice car with power but no driving skills he had 3 attempts all crap
Edited by sssrama
https://www.sau.com.au/forums/topic/117659-friday-nite-calder-drags/
Were you out there racing?
lol wait until my car is fixed up and I go there...then u will see crap!
but every1 has to start somewhere so give him a break!
KJ
it was my car :)
i bloody tried my hardest.. but still never good enough for u is it :D
thanks for publicly embarassing me and my car :(
hope your happy
it was my car :D
i bloody tried my hardest.. but still never good enough for u is it :(
hope your happy
Since when did you get a paint job ;)
And it unfortunately wasn't my car.
But a BIG thumbs up for the guy having a go in a legal environment! :)
sssrama, like to see yourself out there doing better times, and if you can good on ya ;). Maybe the car is set up for track use and is absolutely hopeless for drag racing, just like mine.
give him a break
I was there too on Friday night. His plates were 'KLR33'. Very nice looking car. He did some awesome burn outs at the line, however when it came to race, 1st 2nd and 3rd gears were just backfiring, and he had only moved around 50 mtrs. I think he was too excited, or had a lot of nerves. Or possibly just does not know how to drag race :) Practice makes perfect i guess.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
