Hi All,
Has anyone used/got a Tomei HICAS Lock System??
http://www.nengun.com/catalogue/product/60
I am thinking about getting one, but would like to hear of any experiences with them first..
especially:
1) Is it easy to install yourself?
2) Are the results noticeable? (worth the money) ?
Any feedback is greatly appreciated..
cheers,
-JD
https://www.sau.com.au/forums/topic/117798-hicas-lock-system/
Geoff is not making those lock bars anymore and no longer has any stock of lockbars for the R33, although he appears to still have some for the R32.
Anyways, you can still purchase a solid bar through http://www.greenline.jp
It is called an ESSENTIAL HICAS Breaker.
Anyways a little off-topic to the original question, honestly do a search as I have read numerous threads on locking hicas and plenty of posts on experiences with the Tomei kit.
hmm i was looking at the same kit and it doesnt seem that its a locking bar. Tried mailing them but there reply to me wasnt very helpful >.<
"tomei HICAS lock" in search function turned up about 3 mentions. But none explained how it would work considering it doesnt have a locking bar and the hicas system on the 32 gts-t is hydraulic and not electrical.
So any one who is more apt with the search control please post :P I know that its a relatively popular kit but basically i want 0 movement from the back and wanted to know if this woulda achieve it
thx
My Essential lock bar arrived today :D .
The Tomie kit just locks the hicas rams in the out position with big washers (sydneykid has a few threads on how to copy the tomie kit for free), but it leaves the entire system in place. But a lock bar drops the HICAS rack out, and replaces it, saving weight.
ahh icic, i cant see the hicas weighing more than 5 kilos so im not to worried bout that, ill get the tomei kit (i dont REALLY like removing things that dont came on the car standard) Tried pming GTRgeoff but all i got for a reply is "No" so either he doesnt stock them or make them or has none for 32 gtst
Edited by r32 gts-turbo
I heard the lock bar makes the steering feel heavy on the R33? Can anyone confirm if this is true or not?
i think you are confusing your power steering with your hicas unit....lol. If you remove your power steering, yes your steering will get heavy.
I had noticed no difference in the weight of my steering when my lock bar was put on.
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :P
thanks for that info Greg
Edited by woolls
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :wave:
maybe every car is different.... as I noticed little difference at low speeds
There is quite an obviuos difference between P/S and Hi-cas. When the Hi-cas is removed, some people remove the control unit as well unaware that it also has a role to play in the P/S system. The control unit controls the speed dependant power assisted steering (makes the steering light at low speeds and gradually assists less as you go faster making your steering heavier and giving more feel.). So when you remove the control unit, you also remove this function. so it defaults to the heaviest setting all the time!
Hope that helps! :wave:
Some extra castor on the front almost completely removes the heavy steering that can sometimes occur when removing HICAS. Usually it's only at really low speeds so doesn't bother most people. Extra castor is essential to help your car turn in properly instead of thinking about it then having a go a fgew minutes later :wave:
I tend not to respond to PM's. Nothing wrong with email.
The little black box thats a part of the tomei kit, when installed corrects the slow speed heavy feeling. I had heavy steering as my hicas was on/off, but i put the tomei kit in and its all good now.
No heavy steering at all. It still lets power steering errors apper though (as my speedo stopped working), and the hicas light came on.
This is better than just ripping out the hicas, and removing the globe from the dash.
Well, not if you are using it in a race car, which is the intended recipient for my bars that weigh 0.73kg and 32's can save over 20kgs with all the crap removed.
I only offered bars to road car drivers because they were so expensive at one stage and fixing HICAS can be expensive and is no guarantee it won't go haywire again at some stage. Unfortunately too many think it's just another piece of rice, but I do attempt to weed them out, usually the ones asking for pictures.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
