Ended! Gb: Gktech Front Mount Kits! $400! Ended!
Sorry dezz, I am going to have to take a reincheck, I need a new clutch more than an intercooler at the moment. If the GB is still going in a couple of weeks, I will have another look.
  • Replies 78
No problem mate. i'll hear from you in a few weeks ;)
Put me down 4 1. r33 gts-t.
done :D
sorry for the late reply mate. Put me down for one R33 kit :D
done :)
you ever heard VL turbos making that noise wen they back off the throttle? thats their crazy VL blow off valves....with a front mount, you get a bit of cooler noise....but not exactly what those guys have (which is not cool! lol)
yeah i did, but 2 of them have said they're out...and yeah...
but fear not, ill be sending out a PM to all those on the list, as we're ready to start collecting the $ and the kits will be bought, and sent out :)
check your PM's tomorrow probably guys!
Ok guys
these 10 people have a PM regarding payment!
1. EGA41T - R34 GT-T
2. hayden49 - R33 GTS-T
3. Promax - R33 GTS-T
4. BiAsA - R33 GTS-T
5. Paradizzle - R33 GTS-T
6. mass_iv - R33 GTS-T
7. the_barman82 - R33 GTS-T
8. khunjeng - R33 GTS-T
9. Musky - R33 GTS-T
10. l0WRB - R33 GTS-T
Anyone still interested, its not too late to get in and grab a kit, even after the first lot has been paid for and sent out :angry:
2. hayden49 - R33 GTS-T - PAID
3. Promax - R33 GTS-T - PAID
4. BiAsA - R33 GTS-T - PAID
5. Paradizzle - R33 GTS-T - PAID
6. mass_iv - R33 GTS-T - PAID
7. the_barman82 - R33 GTS-T - PAID
8. khunjeng - R33 GTS-T - PAID
9. Musky - R33 GTS-T - PAID
10. l0wRB - R33 GTS-T - PAID
11. MadTrang - R32 GTS-T - PAID
if you have paid , and its not noted next to your name, it just means it hasn't shown up in the account yet, so be patient. I'll update your status as soon as I see the money in the account :cheers:
Those who haven't paid, please do so ASAP so everyone else can get their kits :ermm:
Can someone please tell me which picture on the front page is the kit for an R33 series 2?
The kit that is pictured is for the GTS-T's.
cheers,
Greg
im in!, i rang the place up today and he told me about it..
i just bought my r33 few days ago, so im down for this, be getting one from him regardless...
if i dont get in the group buy, only save 50 dollars anyhow..
Edited by B-rad33
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
