Hi All,
I have been reading this forum for ages and just got round to signing up...
I have a 92' R32 GTST and have had it for about a year. It was almost completly stock when I got it and it was my first performance car. It felt hella fast, but now I feel it's wearing off. So I have done some mods and would like some feedback on wether I am missing any bits...
Rb20DET
R34 Turbocharger
Apexi sidemount intercooler (looks completly stock)
Bosh fuel pump (400hp)
Malpassi Rising rate fuel pressure regulator
3" turbo back kakimoto exhaust with split dump
Turbotech boost controller
Exhaust cam gear
Stock BOV
Stock Injectors flow tested
Stock AFM
I was aiming for about 180 kw and thought that is more than enough for my car as its a daily driver and I don't need any more power than this.
I was having a couple of problems relating to the factory management. I was getting maximum air sensing from the AFM at 10psi. I was also getting minor pinging at 4700 to 5200 rpm under quick bursts of accelleration. and my fuel economy sucked.
I decided to draw the line on the modifications and I had always planned to get the ECU chipped rather than a power FC due to the cost. and I wanted to wait till all my other mods were done.
I have just got a remap done and I am very impressed. I sent my specs and get a new tune sent to me 4 days later. Pluged the new chip in the computer and the car started YAY!!!. I had the AFR's checked via a mates wideband 02 sensor with a data logger. and am pretty happy with the results. It is quite rich from 5500 to 7000 but I guess that is for safety.
I got the remap done by this guy because I had heard good things about him from a few mates
The car absoutly RIPS now. I am running .9 bar and it is like an animal to drive. it pulls like a freight train and there is heaps more midrange power.
The remap only cost me $160 for the tune, $20 to get the ECU socketed and a case of beer for the loan of the wideband 02 sensor. I really want to get it dynoed just to see how much power it is making but I don't really care about a number.
Anyway let me know what you think. Have I missed anything? would you add anything else? I am really busy at the moment but I will have the car dynoed over the next 2 weeks.
Edited by secondhandninja
https://www.sau.com.au/forums/topic/117983-remapping-an-r32-ecu-done-and-done/
  • Replies 76
I felt sick today. Cough Cough I called is sick and took my car to the dyno doctor LOL
I only did a couple of power runs. I am very happy with the result. The turbotech does a really good job of holding the boost and the new rechip is smack on perfect.
I was told it is an excellent power curve. Is it supposed to be done in 4th gear? there was no sign of pinging the air flow ratios were about 12:1 :D:O:P
I was told it is an excellent power curve. Is it supposed to be done in 4th gear? there was no sign of pinging the air flow ratios were about 12:1 :rofl::rofl::rofl:
Very impressive results $160 well spent pitty us Rb25 guys cant get this done
Yes they can. There needs to be a small modification for the VCT but I have seen it done before on RB25 with good results.
this guy is a absolute champ, sent him a email today at about 12pm and got a reply now at 1:20pm.. he is going to make one up for me as soon as i pay for it... can't wait to see what sort of gains i'll get. let you guys know how it goes. :)
I don't have a dyno with AFR's unfortunatly. they were tested on the dyno and I asked for them :woot: but insted I got a printout of boost :wave:
I didn't look till after I was gone so i couldnt get em to print out another one. I did get them checked and even saw them on the dyno computer screen.
Yoshitokio is in threadbo of all places. I will email him and tell him there is some interest on this site.
i did a similar thing....
bought a copied chip of someone off this forum who had similar mods to me minus the cooler for $50, took to my mate to get the cradle soldered in and wham bam thank you maam ive got more power, response, economy and speed cut removed, higher rev limit etc etc...
very happy
he gives u a preset tune depending on the mods u tell him you have and then u take it down the dyno and make sure its safe ?
im pretty sure thats how it goes down dude.
hes guessing from another state.
i dont know squat about tuning but i always assumed each car is different and u needa get it on the dyno and adjust stuff in realtime.
but yeah i dont know shit.
Yep is is tuned for the mods you list. and you then go by your self to the dyno to get it checked, He guaranteed me if i didn't get a power increase he would write another tune for me after seeing the dyno sheet.
You can get upto 3 seperate tunes sent to you, dyno all 3 and keep the one that suits your car best and send the other 2 back but it costs a bit extra. He was confident he would get it right first time and he did.
I have gone through a full tank of gas since the tune and got 460km's to the tank. that was slightly less than i normally get 490kms. But I put this down to my heavier right foot!
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
