  • Replies 504
i mean umm don't get me wrong guys.. skylines are great.. but why did they change touring cars from turbos to v8's????
yeah thats right
*dons flame suit and runs out* muahah
Lol..dont think your flame suit can protect you from shotgun pellets!
They changed touring cars from turbos to v8s so the v8s can start having a chance at winning!:P
Makes me wonder though if a NSX-R can beat those v8 touring cars..
I owned a V8 Commodore.
Cost me close to 5k in repair bills within 9months of owning it.
First.. Subframe cracked where the diff mounts up (IRS)
Second.. Gearbox bearings died
Third.. LSD Diff openwheeling and grinding really bad.
So my nice 'solid' lol commodore was not so solid after all, for a daily cruiser yes maybe, if I could put up with the rattles. But as a car that will handle a bit of a hammering, no. >_<
I freaked the first time I jacked the commodore up, opened the drivers door to grab the phone went to close the door and noticed my nice 'solid' commodore's door wouldn't close as the whole body twists when the car is jacked up. It was literally a good 5cm's out. :S
Talk about a solid chassis. No wonder those things split in 2 in high speed accident. :P
I've owned one so I can pay out on them. :)
Touring cars where changed for all the Ford and Holden fans to have a sport where drinking and lack of intelligence is encouraged over a very long day, which BTW finished quicker when the skylines where racing :laugh: .
If Holden and Ford aren't so scared why did they knock back Toyota from entering the V8 supercars?
Because they know even a fridge on wheels will kick their ARSSSSSS!
Edited by fuzzy_scuz
AHYES.
hahaha....gold
where's ash these days?
he's around. we just went down to melbourne last weekend and he ended up buying a track car. a '71 Torana LC. who would have thought the drag boy would go circuit ay.
hey dave, your sig reminds me of your poor little car being written off. if i remember correctly you wrote that in shortly after when you had the shits with cars...?
so he has a car that can turn corners now? he must be growing up!!! haha
does he still have the drag car?
yeah, very shortly after i had the shits with cars...that didn't last too long, now i'm having a very hard time just trying to not sell my golf and buy something stupid
how's the 240?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
