for get genuine rubbers for the front and rear screens just use commonwhore ones look better and are a shitload cheaper
the rear quater windows have either one or two 10mm bolts holding em in as well as the usual silastic
ive never seen em come seperate from seals
  • Replies 98
Do you know of any window place that has actually replaced the seals? I've head of using the bomodore seals (and IIRC someone else mentioned using a Mitsubishi mirage seal to me once) but I don't want to rock up to the local Obriens only to have the person ask "what's a skyline? R32" or have dollar signs light up in their eyes :)
im sure it was $120 ea for the soft rubber as both my drivers and passenger side glass rubbers are shagged at the top corners. I rang the guy here in Adelaide (Unley Nissan) and he recently got them for his own 32 GTR and he knew exaclty what i wanted.
I need the hard bits too as some f*kwit tried to break into my car and ive got screwdriver marks along the hard rubbers.
linky no worky as well :)
that sounds great, do you think you could buy a pair for me? I'm happy to send the the $$ and postage. I just need them asasp. $120 each is fine.
R
R
I dont know if i would get quoted the same price again. Ive rung up before (2 separate times) for some other parts, and depending on who you speak to, and sometimes time of day you get quoted different prices...
I'll have to ring back and double check....im sure he said $120 at the time i enquired though....
cool. heres some pics that may help:
the seal:
where it starts from:
where it ends:
and one i knocked up with my paint skills showing where it is:
anyway just see what you can do. thanks mate.
Beer Baron,
I've had a look at the fast diagram you posted, My drivers window rubber recently died, I called Nissan I remember they quoted high 200's.
$280 rings a bell for some reason.
thanks mate, that helps too. it's still better than the $440 each the blokes here quoted (trade price). and that was trying two different nissan parts dealers.
now were are cooking! i have half of sau on the case. i even have my friend in japan going to go and contact his local trade parts nissan dealer in tokyo. if the are really cheap there i may grab a whole bunch.
thanks guys :D
i used BA falcon seals on my front and rear screens, but that was 33 .. but i doubt there would be much thickness difference in the glass itself..
and it just came in a length, years ago now, but was only just over $120 or so for front and rear from o'briens.
thanks guys :D
now hand over your gts-t :D
thanks craved. yep my glass dude who is removing the screens said they just use a generic seal to do the windscreens front and rear, but the door windows are a different story. you definately will need the nissan ones for those. :D
haha hand over my GTST. my poor gtst wont even get new seals. they are for the GTR only! :D
so when calling obriens you just ask them to replace the rear windows seals? mine leak, so i gotta get the sorted before winter kicks in.
steve
Start soaking that rear wiper nut RIGHT NOW!. :fakenopic:
Grab the best silicon/penetrating spray you can as you don't want that rear window broken. :S
the seals around the door and window are around $220ea from Nissan AU. I bought a pair.
Part numbers
N7686004U01 - RHS
N7686104U01 - LHS
From the Japan parts thread.
I replaced that exact seal when I got my car.
These are the part numbers on my invoice.
PS baron your pictures are $hithouse :fakenopic:
haha thanks lover. you know i should have been a photographer!
so just to confirm (cause every time i ring nissan i get a different number). they are the soft rubber seals that run from the height of the striker plate up and around the window and stop at the base of the a pillar? woohoo. that is much better than $440 each piece.
yep that's the one.
I had the std R32 tear in the top corner of my door seal and it was annoying me so replaced them ;)
starts at the base of where the b-pillar trim meets the body, runs up the b-pillar, arcoss the roof, down the a-pillar and meets basically just below where the wing mirror would seal up against.
do it. you know you want to...
YES YES YES.
i love you ronin. love you long time.
i am so sad i was nearly considering even buying them at the $440 each. f**k me.
i will ring nissan again with the part numbers and see how i go.
thanks mate.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
