getting a 2 way might not be that bad. U might have scored a Pro LSD which u can adjust the preload on it....which is the same diff i have :D
How much preload variation can you get on this? Does it use the stock inner C/V joints / stub axles? Can you get alternative ramp angles for it? Was thinking of getting one of those! Cheers
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191520
from memory 4kg, 7kg, and 12kg preload (ie soft medium and hard) Mine uses (in r32 gtst) stock everything. It should come with new stub axle bearings too in a new kit? Im not sure but mine was a complete overhaul done. Only thing is i want a ratio change now so im swapping to a 3.9 r200 shortnose crownwheel and pinion :D
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191558
Thanks for the speedy reply! Are they available in both 1.5 and 2 way? Any idea if the ramp angles are available in alternative configurations for 1.5 way? Cheers.
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191609
I'tll only step out if you want it to ie dont pop the clutch on a down change. If you are braking hard, push the clutch in and hold it (like u normally do)
Ive had to do an emergency brake before (some moron pulled across infront of me, then stopped) and i clutched it and braked at the same time. It stopped like a normal car would.
People seem to worry too much with these diffs....
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2193606
dude. take a pic of the damm thing about 3inches away from the whole!!!
i cant see shit in that photo. :starwars:
like phatr32's pic kthanx
whats this diff (its in the front of our GTR)
sorry for the lame pic...its the best i could do
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2198381
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
