Hi All,
Driving up to Shepparton Friday night after work - don't want to drive alone......
Then join the DECA Convoy!!!!
When are we leaving
Friday evening
Meeting point address
Shell Roadhouse
Hume Hwy
Donnybrook VIC 3064
Melway 365 C5
Meet Time
7.30pm
Bring
Adequate Fuel
CB Radio - Channel 14
Tour Leader
James
https://www.sau.com.au/forums/topic/119043-deca-convoy/
James, the WRX guys are meeting at 6:20pm at STi @docklands if you want to join us for the drive around to Donnybrook.
Just a thought, what are people doing for food?
Do you mind if I tag along please? I only live 2 mins around the corner in Port Melbourne.
Was sat with a rex STI 9 all the way from my work exit in Dandenong to Kings Way last night. Passed about 5 other rexes and a clone of my car. Bizzare Subaru journey. :D
https://www.sau.com.au/forums/topic/119043-deca-convoy/#findComment-2196070
Age - I'll meet you at Donnybrook. Can you guys stop in - or give me a call when you getting closer?
Saff - We don't stop until Shepparton, so either grab something earlier or put up with the truckstop food. I reccommend the former :D
https://www.sau.com.au/forums/topic/119043-deca-convoy/#findComment-2198058
Yeah no worries Jame...i'll call you or Ash. We are planning to meet you all anyway, and cruise up togther.
Saff
No worries....see you at STi@docklands. We'll be there from 6:15, and we leave at 6:30 for the casual cruise to Donnybrook. We are thinking of stopping for Maccas on the ring road.
I'll be in a dark gunmetal new suzuki swift.
https://www.sau.com.au/forums/topic/119043-deca-convoy/#findComment-2198633
Saff
AGE Thanks mate, will be driving a blue liberty with SAU stickers. Just waiting to hear back from Mav as to what time he can get out of work so will let you know either way whether we will make it or not.
Jam No worries, thanks for the info. :)
https://www.sau.com.au/forums/topic/119043-deca-convoy/#findComment-2199106
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
