So i take it you arent going to DECA then?? you should do the box change over and see if it keeps staying engaged, then cancel deca. it may sort itself out with the chance over... glimmer of hope for ya.. Im free thursday too if ya go through with it
  • Replies 53
Well, not sure at this stage...
Thanks for the offer Ryan. From what I've been told, if it doesn't fix the problem, the car will still drive fine, but I have a higher chance of smashing this box aswell, which I can't afford to do right now, not for the next 3 months or so that is, so I don't know if I want to risk it.
I also don't want all you guys to bust your balls for me on a whim if you know what I mean, I'd just feel bad about it...
If your clutch is a bit ???? and your rear main seal a bit ???? then i would be waiting and doign it all properly.
What exactly is wrong with the clutch that means its not disengaging? I dont know but that sounds to be an adjustment thing ????
But do it right, missing a DECA sux but you do have a back up car or two :P
Buy a new clutch. Rebuild the old clutch later and sell it off as a rebuilt clutch.
The extreme clutch supplier dude that me and Al have used will deliver next day.
Wack the new clutch and BOX in on thu night and bob's my dad.
Don't worry about the time taken to do it. As Ash said, it wont take all night.
Is it currently a twin plate?
I will also be available for Thursday night, so i will give Dave a call on Thursday to get an update.
On a another note, i may have to pull my car out of DECA :D.
Went for a drive on the weekend and was hearing a deep winding noise from the engine bay, at idle. Tracked it down to behind the cam covers. Will be taking the car to my mechanic tommorrow to have a listen, if he knows all is ok, then no problem, but if he suspects a fault then i will pull out :(. I was so pumped up for this event :ermm:
Either way i will still come up!
Anyone got a spare 33 i can borrow? ;)
heh, i may still have my old clutch layin round, but i doubt you would want to do that, especially at deca. the only good thing is your gearbox wont be hurt in the slightest as it will probably never fully engage with all the clutch dumping. as for putting everyone out i think we see it as something to do!!! would be a bit of fun;)
Daneeeee
Im more than happy to give ya a hand with all this, and even if its the clutch, we can look at it with the box off, its the best time for it.
its for free dude, you might as well give it a try and see if its worth it.
Cheers
Sean.
Troy: I'm not sure exactly what makes it not disengage fully, but it's something to do with a few stress fractures I have in the clutch plates. I've been strongly advised not to put another box in without fixing it. In their words the clutch is 'f**ked!'
Chris: Yeah, it's currently a twin plate OS. Just buying another clutch would be the easy option, I work right next to EXEDY, but I simply can't afford it at the moment. I just put a fair amount of money into it last week...
Ryan: Thanks man, appreciate the offer dude!
Sean: thanks man, why is it always you that ends up fixing my car?? :D haha
Realistically, I think the only way to get it to DECA is to put another clutch into it, whether that be a secondhand one I can borrow, or a new one, which is just not an option at this stage...
ahhhhhh well...
I've just pulled out of DECA...
Thanks for the offers guys, much appreciated, but I should just do it once and do it properley with a rebuilt clutch I think.
no one else will say it, but im a kent so its ok....few more withdrawals and we can double our pan time!
oh yeh, bad luck with the car :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
