That is an angry looking ferrit. It looks like my wearhouse manager! HAAH!
BTW, Im going to be a defencive driving instructor! WOOH! IE interview went well. Not full time tho, so I still have to find a new full time job.
You ate too many green M&Ms didn't you
NEVA!!!
That is good that the interview went well... but not god that is is not full time :cheers:
so free defensive driving courses for all SAU members ... excellent
Graphic artists annoy me. They can’t get one single thing right, the world is aginest developments.
Ig I have to explain one more time how I want my art work done I’m going to go eat razor blades.
maybe they can't understand you because of your atrocious spelling skills?
Website names that should have had more thought put into them
1) Who Represents? - a database for agencies to the rich and famous: http://www.whorepresents.com
2) Experts Exchange, a knowledge base where programmers can exchange Advice and views: http://www.expertsexchange.com
3) Looking for a pen? Look no further than Pen Island: http://www.penisland.net
4) Need a therapist? http://www.therapistfinder.com
5) Mole Station Native Nursery, based in New South Wales: http://www.molestationnursery.com
6) Gas central heating anyone? http://www.gasheating.co.uk
7) New to Milan and you need electric light? Why not sign up on-line with PowerGen? http://www.powergenitalia.com
The missus and I were continually having fights over money. She told me we had to cut back on expenses - I had to give up drinking beer. I was not a big drinker, maybe a dozen on weekends.
Anyway, I gave it up but I noticed the other day when she came home from grocery shopping the receipt included $45 in makeup.
I said, "Wait a minute I've given up beer and you haven't given up anything!"
She said, "I buy that makeup, so I can look pretty for you."
I told her, "f *k off, that's what the beer was for!"
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
