:P
Hey Anna, I see your still enjoying yourself in whoretown...
How ya goin Col?
Hey Terry good mate....
I drove the skyline today for the first time in months...
She went supersonic on bridgeman rd out the back from my house...
28psi produced somwhere round the 350rwkw and she steped all over the road in 4th gear as she came onto boost... So im very happy, I have ripped down the back end of the turbo and am heat wrapping it all and just finishing off all the little bits before the dyno next Saturday for tuning...
The reason i hit 28psi was I didnt plumb the ext wastegate correctlly so ill fix that tomorrow and ill test it out...
Let me tell you its about twice as loud now when she comes onto boost...
Ill have to show you, you will be blown away as to how loud it is now...
The BOV is now mounted in the front right hand guard and the air filter is now in the front left guard so I have 2 separate air in and air out areas, complying with the ARD's rules and completlly legal... :)
well i'm gonna head off kiddo's!!
have a great night spammin ;)
Night Anna
kiss kiss
When I put my new turbo and front pipe on it was farkin loud too, I got a resonator installed in the straight bit after the cat, took alot of the growl out of it, its still loud but you have heard it and I wouldnt say its too loud, just right for me
Angry parents complained about a ninth-grade teacher who handed out a "joke" math test to his students that was offensive to Latinos. The mock test passed out by Charles Sanders included math problems such as: "(A person) is in prison sentenced to six years for murder. He got $10,000 for the hit. If his common-law wife is spending $100 per month, how much money will be left when he gets out of prison and how many years would he get after he kills her for spending the money?" Sanders was placed on paid administrative leave while the school district concludes the investigation. "We want him fired!" said Louise Palomarez of the Mexican Political Association. "We don't want no damn apology."
Can someone explain to me, why the holden hsv gts tv ad, has a thing that says australia 1, germany 0????/
i cant figure it out
dare say its to do with the soccer. Sad that obviously holden think they've made a better car than germany...hmm yea...ok. Even if they have (which i doubt) germany have like 1000 over us. so its more like 1 to 10,000
so they are comparing their shit car, to a soccer team???
honestly, i think i would take a german made car over an over priced VE GTS, they look to cheap.
hahaha soccer what fools
They are comparing that australia has better engineered vehicle & handling then germany does. ha ha i doubt it.
When the HSV GTS first came out (2000 or so?) they took it to the Nurburg ring against the (at the time) current M5 and the AMG E55. Anders Olafsson said the GTS was by far the best drivers car there and it set the fastest lap, wasnt as pretty inside but.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
