so i could convert to solid lifters...or what size is max on hydro lifters.
9.something mm lift, tiny tiny cams compared to a solid head
u could convert it to solid, jhh does it for $400
Me.... Cams....
No, the car will be gone in 6 weeks, why would I put cams in it???
caus i reckon u wont sell it lol. and to turn ur car from a power skidder to a useable powerd car :)
hey guys,
my diff is rooted! along with my clutch... s133gtst
looking at my options,
-Shimming
-New Diff (thinking Kazz 1.5 from slide)
-Second hand stock
-Second hand gtr
there are a few second hand gtr diffs floating around are they an upgrade over my stocker and do they fit up? I think noel was saying he had a gtr diff in his.
whats the best way to go, I can afford a new one but i would much rather spend my money on another part of the car, also fitting it myself.
Cheers,
Dan
myeah i want something from with power range from 3000 - 9000+
and i want a rotary idle mostly...:)
hey guys,
-Shimming
-Second hand stock
-Second hand gtr
Cheers,
Dan
either 1.5 way or gtr diff....shimming myeah dont think it would last as long.
I'm wiht oblivion!!!
if you get a 1.5 way or a gtr diff, you can kind of forget about it.. once it's done, it's done! where as shimming your current one, you'll more than likely have to do it again a few months down the track!
I've just ordered my 1.5way from slider, after months and months of umming and arrrring over the issue!
I want a turbo right now, So I can just look at it, fondle it, blow in it and get hypnotised by the whirling blades. Polish it. Show it to the cat.
sigh
hahahaha
hey guys,
-Shimming
-Second hand stock
-Second hand gtr
Cheers,
Dan
Yes i do have the alsd option in my 33. (as does Andy) That said i dont think it would be an easy conversion to make. there is the electronic side of it along with the hydraulic set up to consider as well. If your car didnt have the alsd from the get go i think you might be better off looking at the other options.
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
