does anyone know if the JJR Hyperflow exhaust or the x-force one are any good?
I,ve used xforce in the past and they are fine. A tad louder than some but a great free flowing exhaust nonetheless.
But your right, cars are far safer, hecne you have to ride not only safelly yourself but keep an eye on everyone else on the road...
Yep i'll vouch for that was riding on a dead straight road only myself and 1 car coming the other way, wasn't doing anything stupid and she turned straight into me, had no time to do a thing. Went flying 20metres was very lucky i wasn't badly injured or killed. Been sitting on my ass for the last 2 weeks going to the doctors everyday to get my leg redressed, i think i'm gonna give the bike away for a while to many moron's on the roads, not that i have a choice bike's a ride off.
Hate to burst your bubble Shane. Non V-spec GTR's already have a 2 way.
must be pretty lose then...almost as loose as josh's mum's c...:P
on a side note - theyre open diff fronts right? ur thoughts of 1.5way front 2way rear? (ATS carbon)
Hey hey Joshwa
Whats doing?
Spent some time up your way over xmas, was nice to break out the jet ski again!!!
Just looking at cars forsale... About it really. That an I have a cold and feel like shit lol.
Hahah.. Yeh need to watch out for the DPI wankers.. Know them all too well.
The fronts are open and the rears are set a little loose to allow for it being a road car. But at least they can be shimmed up, unlike the V-spec crap which is considered economically unrepairable when they crap out (like on most V-specs that do some serious track) so they then have to find a replacement and most go for a non V-spec because they are repairable and adjustable. So not sure how that's crap Josh :D
Shane, just reshim the rear and get a decent one way front. 1.5 is a bit much on the front.
The fronts are open and the rears are set a little loose to allow for it being a road car. But at least they can be shimmed up, unlike the V-spec crap which is considered economically unrepairable when they crap out (like on most V-specs that do some serious track) so they then have to find a replacement and most go for a non V-spec because they are repairable and adjustable. So not sure how that's crap Josh :P
Not so much crap as such, just more devo’d, after spending all night putting a GTR rear cradle into a gtst then to have it still single peel haha :laughing-smiley-014:
Nothing a few hours and some shims didn't fix though
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
