Most people haven't even heard of Skype it's still so new. But for us former executive management types it's perfect. Calls are cheap as well to mobiles and landlines. I just had a half hour video call with a mate in Melbourne. Free as an VOIP phone with video. I even have it on my E65 through an app called Fring that allows me to take VOIP calls in a wireless node like I have at home.
IM on the other hand is complete rubbish and I shudder at the number of people that have had virus infections through it. And I remember IM and ICQ from when I was in Uni in 96.
But if cool means using the stuff all the semi-IT literates use then yep, I must be uncool. :D
Your explanations are far too long for whore town.
Let me drive some cool euro shit. I'll give you hugs/money :laugh:
SHAN Anna and i need a flatmate we should be living at Mt Gravatt east soon in a nice 3 bedroom town house with pool, 25 minutes to the city by bus and 15-20minutes drive to Logan
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :)
Main reason I don't like skype is that the protocol's insecure, and even if you're not using the program, data is relayed thru your PC for other people's call (which is how the protocol works... link all the nodes that give the quickest ping and go thru them)... which when your upload and download limits are tight, don't work well in my favour.
Otherwise for the rates n stuff I'd be all over it.
I should probably install it, and only run it when I need to make a call :P
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :laugh:
I should probably install it, and only run it when I need to make a call :)
Ya there is a lock up garage, plus the complex has a big gate on it that you cant get out of with out a swipe card...makes stealing cars from there pretty hard :)
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :D
I should probably install it, and only run it when I need to make a call :D
Pfft. Of course you wanna walk in on sexy times. Andy makes most of the guys in the club go weak at the knees. :P
Shan, you may as well cut you wedding veg out and get a Mac if your that limp about security mate :)
/short response to keep everyones attention span/
Bahahahah he's never stepped foot inside Family, but he was a frequenter at the Beat about 8 months back, AND I have witnessed him dance to Craig David. Admittedly he had swallowed quite a bit of Virgin Bourbon at the time :thumbsup:
:laughing-smiley-014:
btw, omg ur back in whoretown!
I pity the following people
Who posted in: Whoretown - Beware Of Ginger Ninjas!
Poster Posts
shanef 8143
Nismo_Boy 4577
Silver_R34_GT-T 4207
phatboi2010 3102
Keegs 2636
markimak 2384
Mr-Toy33 2331
impact_blue 2204
Bunta 2178
Col-GTSX 1983
lilmike86 1965
LIL34 1947
SMR33 1894
Konrad 1888
FineLine 1849
85URK 1314
Oblivion 1279
SLO-89 1027
Squizz 950
Mushroom 941
dano4127 814
Revhead 726
Mr Kofi Ahmed 623
Liz 608
LBR33 535
Rhinorebel 525
R33S2 492
donkey_punch 487
zaffa 471
dangerous_daveo 369
IanB 362
subzeroR33 354
Ska 325
Mud 246
AzzurrA 234
3lit3 32 220
RusH_ 217
shnaped_second 206
T04GTR 193
Devils_Advocate21 174
666DAN 164
EnGaGe 161
predator 158
ZENNON 155
Eug 142
Slide 135
Hell Fire 135
Nexus9 135
pear 127
Oz 122
S04R3R 120
SmoothLine 104
Strik3r 102
DOU33 90
ze_flexy_1 86
frankxinyu 85
r33_racer 83
Demoniak 77
d00dz 77
Wagamama 64
ZOR 64
BLiNKsTaR 61
*..KITAS..* 60
AZN25T 57
Jdfnq 57
K N P 56
D_I_F 53
Noy 51
chaos 47
GTSTGIRL 47
Einstein 43
myR32 41
prego 40
aphid 40
NismoGirl 40
choyda 38
RetardedMonkey 36
Ed G 36
GTRgeoff 36
Ivonin 35
spilmer 34
ookami 34
VL-TRBO-RB20 32
GTR_KILLA_VC 32
n15m0 30
N1GTR 30
SAM112 28
sik_vs 26
mrbenno 26
jaqule 24
Lazy-Bastard 23
sloazr33 23
D-limo 22
silverbulletR33 21
miss_petepie 21
Sl!m 18
gts25t4door 17
jibbz 17
Rednisr31 17
sweetr33 16
Crimpage 16
NFAA32 16
BoostdR32 15
booosted33 15
OBNXSH 15
sh@un 15
RB_turbo_bitch 15
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
