Get a hair cut and get a job Josh. :(
I have a hair cut; bollockser cost me $250 as well. It’s just a little longer in length, then most “normal” people haha.
As much as I should get a job, I really can’t. I’m involved in litigation (still) with my bank. If I work I have an income, thus known money assets in known bank accounts.
If I don’t work, what the situation is stays the same and would be ruled in my favor. Some people say it’s corrupt, personally I’m using legal loop holes to fix something that shouldn’t have happened
the mod plate covers the 2 seater mod, roll cage, turbo, induction, suspension and pretty much everything else. Its registered as a 2 seater as well. The only dramas with it atm are the screamer pipe, ride height, exhaust volume and BOV...
Thats good news, when you said it had a screamer i thought what else went past the eyes of the mechanic that did the roadworthy...
Just the fact that there is no longer an airbag and the headlights are series 1 units makes me wonder if it has had a front ender at some stage of its life...???
I did a quick count of Jaqules list and there are at least 18 people on there that don't even own Skylines let have one that runs!!!
I got enough parts to make a whole skyline again, but I didnt strip it out of the donor to put it back together in its original chassis... :D
loses a lot of power, but fine for putting around on the streets, and takes 20 seconds to install/remove.
Like your kind of thinking :thumbup:
he's provided me with the original steering wheel with airbag included. the series 3 front lights were swapped during compliancing. The silencer is harder to fit than i thought.. not because its complicated, but just cause the bastard of a thing is a really tight fit and requires a bit of elbow grease to get it in. so ill revise 20 seconds to '2 minutes' :D having an absolute blast.. car is really well put together.. engine loves revving, and sounds so angry. im not ready for the march 25th track day, but ill be at the next one :D
heres a pic from today:
I find it just doesn't respond enough.
You're just too used to it Geoff. I'll give you mine for a wk (pre-tune) & that should put it all back in perspective for ya :D
320Kw would do me for a 'lil while
It’s not that old.. It’s a 1990, although the technology in it is still 30 years old lol. Water-cooled one's are the devil… Can you tell what part of the Porsche car club band camp I come from :D
They are more of a driver’s car IMHO, takes a whole lot more to control one, I find GTR’s boring, predictable, unexciting and an easier car to drive, plus I hate 4wd/awd… But I am narrow minded and don’t like all this technology, atleast I can admit it haha. Admittedly I’ve never driven a GTR like old mates one he just bought, but driving a 600rwhp S13 for a few years makes me a bit rwd bias I guess
There is no doubting that the GTR is the better, more advanced car (compared to early Porsches) and will win every time against "most" of the earlier 911’s. Although, we had a genuine RUF a little while ago, that would, could and still would (if it were still around) dust most mild GTR’s.
But that’s kinda comparing different leagues and not really relevant.
Yall own Nissan Pulsars :D All this from me hating tire to wheel arch gap :D
no drives for you then joshy :D
Get a mate to flim you doing fly byes on boost. I wana hear it at WOT :D
+1
ur forgetting about the 500kg weight penalty everytime geoff drives it...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
