page? lame missed out.
how's things marc? say hi to karen for me.
eug
Yeah good mate, I'm missing out on holidays over the xmas break this year (someone else beat me to it lol) but otherwise things are going alright.
Also Karen says "awwww he's so sweet and Tina too, hi Eug <3" :P
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
