page? lame missed out.
how's things marc? say hi to karen for me.
eug
Yeah good mate, I'm missing out on holidays over the xmas break this year (someone else beat me to it lol) but otherwise things are going alright.
Also Karen says "awwww he's so sweet and Tina too, hi Eug <3" :P
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
