hmm..im after those that you have to wash yourself ..as in like you put in a dollar and gives you whatever 60 seconds of the soapy brush or high pressure rinse etc..
not the touchless ones attached to servo's
yeah one at greenslopes is self serve or self wash
I might be up for it. Cars going in for a mild tune tomorrow and I'm quite eager to find out it's potential down the 1/4 :turned:
sweet. I will have a look through the tnt dates and might even post it in the events section.
  • 5 weeks later...
