i work in a bakery just outside toowoomba, ours arnt too bad... the more sugar and vannilla in the cream the better :P
So who makes good lamingtons these days? Haven't had a decent jam n cream filled lamington in years.
  • 3 weeks later...
  • 3 weeks later...
Rents are moving to toowoomba, i had a customer tell me yesterday it's the gay capital of the darling downs?
  • 1 month later...
Hoping before Christmas pending my wife's work load.
PFFFT to dyno fear...I tuned my car on a hired dyno and it's not hard. So if you're at a reputable place and the engine isnt flawed it'll be sweet.
