Gt2860, multi tool swiss army thingy, tshirt, LP style coasters, jaycar electronics kit, all terrain robot, CAMS battery location sticker, DATSUN keyfob for the C210, and a few trinkety things
As much as I love eating them...December is to early.
100% agree!!
It use to annoy me when i worked at coles 10 years ago that they would have hot cross buns out in early february, but now it's pretty much as soon as christmas is finished. Way too early.
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
