Yup. She is. Night whores!
No I wasn't. I pay Tony a compliment and everyone thinks I'm on the piss
Morning, same. Do. Not. Want. Work.
Too tired?? *giggle*
Morning all :) it's gunna be a great day. A top of 22 for me and I will be wearing a jumper all day at work haha
I like this positive-ness. I like you. You can stay here *points to a giant pink comfy chair*
Morning all. Another Monday grrrrrrrr..........Mondays I could kill Mondays.
But then Tuesday will be Monday.
You know what..... SHUT UP!
Atleast I can look after my car for free :P
But yeah she gets so much more pay than me :(
You guys have it made. You can fix her car and she can install power points in the garage for you :P
I will be unpacking the new place today AND laundry...and laundry...and laundry. Oh and if I get some time I might go to this info session on running a food business in Queensland.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
