Didn't have anything to drink. My hands were really sore yesterday. Assumed that it was just the cold playing with the metal plates. Got home after dropping off the leopard and just crashed. Was out till dinner and then just passed out. Didn't wake up until 7:30am today and couldn't balance or stand straight. At work but don't know how long I will last.
i want to see you go through an airport scanner. actually, maybe i don't. i am guessing they will make you strip down because of all the metal in your body.
Surgical steel doesn't send it off. :) Been through many scanners.
So what your saying... Is, your kinda like wolverine
Chants calls me this regularly..
not really, it would just be more interesting to see airport security hassle a black man :P
Figures of 'perceived' authority enjoy hassling me
Well we did determine on friday night that cops love hassling black men even more than they love defecting and booking hoons
Yes. We did...
thought I would post pics of last weekends day to Springbrook national park
the view
surfers paradise in the middle
it was freezing up there and I came ill prepared - so my good friend Slava gave me this - genuine Nürburgring soft shell jacket ;)
whilst on Germany - das beer (German beer da bomb y'all)
das food!!
All in all (finger boy's favourite saying :dry: ) - EPIC DAY!!
That's fuarked. Tell them to payu for it as it's their f-up.
Oh they have said they will pay me for it. But I have to fork out the money, and then hope that they actually do... :(
This guy, he knows.
Looked like a top day mr ants
sure was Nick........after that we headed back home......cracked a few more whist watchin F1 qually.
will go back there again soon.
all of this is makin me hungry and THIRSTY!!!!!!!
Yer 4 days till opens then will be hitting up a decent cruise somewhere with the brosephs for a weekend I think.
Haven't had a decent run in ages, we all have such different cars
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
