This is ridiculously hilarious! Keep them coming.
1. Dragunov - excellent range from the top of a tall building.
2. 2x Uzis - for when they get too close to the top of my awesome tall building.
3. Samurai Sword - if it gets to this stage, might as well have fun.
4. Mighty car mods zombie mobile. :)
Sorry Ben, I am not "unhappy" with the move back here, in fact I find it funny that even though we have moved back here, we still have 2 whoretowns... Kind of defeats the purpose???
agreed about whoretown. don't need a members section whoretown.
And Ant, who is that hottie you posted?
agreed about whoretown. don't need a members section whoretown. And Ant, who is that hottie you posted?
Chants wanted sexy cleavage so I thought I would post a pic of my sister from Barcelona
gotcha! just a random hottie Benno ;)
If you were in a zombie apocalypse and could only have four weapons, what would they be?
1 primary gun
1 secondary gun
1 melee weapon
1 vehicle or misc weapon
dont know actual brands and such, so going to generalise
sniper rifle
chain gun
katana
gtr
Imagine the people, the places, the things you once knew were not gone, were not dead but never existed. What type of hell would that be?
A Beautiful Mind
A great movie but such a terrible tale of what happened to an absolute genius. It's funny how life gives us so much but then cripples us when we least expect it. The entire concept of having what you perceive to be reality being pulled out from under your feet is truly shocking.
Food for thought. :)
A Beautiful Mind
was also watching.
really like the movie.
and is 'based on a true story', so even more thought provoking.
just stop and think for a second, how do you know every single person you have spoken to exists?
you dont.
you cant.
but, we take it for granted.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
