I don't remember you Nick , sorry
People I do remember
impact blue
Predator
Chaos
Cyras
Mud
Well, Beau, your memory is just as sharp as ever... What about Bunta??? You cannot have Impact Blue without Bunta!!!!!!!
And what about Revhead??
impact blue
Predator
Chaos
Cyras
Mud
And Charlie. Lol
Charlie... sad little man... But a great target on here!!!
Of course Squizz, cannot forget Squizz who has gone to the darkside and has forgotten his Skyline roots...
And Col... Who can forget Col!!!
Col is still around from time to time Rhinorebal
Well Impact Blue is sitting about 2m from me, she just think you guys are feggits so doesn't go to stuff :P
</3
then again, the 1/4 mile has more curves than taylor....
LOL!
You guys have been ragging on a guy with a LS1 in a 33, but I have been in a 33 with a 1UZ
33 with a 1UZ = awesome
33 with an LS1 = abomination
Morning!
Quad cam and 6 bolt mains > pushrod heap of 'murica shit.
In other news my brother in law has decided to buy a R35 GTR. I am very excite. Have wanted to drive one for a while now.
Theses guys are waaaaaaaayyyyyyyyg old or even dead as I've been around here longer than you bro.
LOL just a lot of us are in the 10+ years of SAU membership, I've been pretty scarce since I moved on from the LED business, that was the only thing keeping me here as I said good bye to the R34 about 3 years ago :(
I've heard if you look into the mirror and chant "Charlie, Charlie, Charlie" he will appear in Whoretown!?!?!?!?!
We can't all be LS1 haters, I will be putting an LS(insert number here) into a car in the not too distant Future but I've got a bit of a timeline and process to go through before it hits the streets....28 months and counting.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
