and your type come and go.
notice how you werent present for a while there.
Fair point. I wander off every now and then, but I'm old, it's what we do. I do notice however you claim to have all but invented the art of post whoring, in a thread on the very subject, that's been around longer than you have.
not invented, developed.
OG piss me off with their 'better than you' attitude.
yeah, you left.
yeah, I came.
yeah, shits changed.
deal with it.
African American *three finger click thingo*
Mmmhmmm that's right honey you tell em lukey, you are a strong independent black women :yes:
Careful, he'll tell you he invented the finger-snap long before the empowered women of African lineage.
Alrighty, it's all good to laugh and joke and each other in jest as that is the nature of this thread. Personal attacks and what not will not be tolerated. Lets just keep this a happy, light hearted thread.
If this keeps up we may have to lock this off and use the members only thread. Wait, that only for members...
Amateur...
FINALLY!!!!!!!!!!!!!!
Amateur...
and yet he's right mate.
Amateur...
Say what you will mate. You move on over 7 years ago and things have changed since then. The club has gone from highs to lows in that time like any business and is run differently these days. If you don't like it, feel free to move on. I'm sure that you still have the contact details of the guys that you enjoyed whoring with in the good ol days. Things have changed and people have moved on. Being an OG, people have you respect and you treated them like pricks.
If you helped start up this place then you surely know where the door is. Feel free to use it if you don't like what's happening here.
  • Like 1
I don't have one, ill borrow yours... We're the same size right :P
That's a negative, You're 2 cylinders larger....
Hmm, i really need to pay my membership... need to try not be broke... #businessOwnerLyf
For a non-serious thread you all seem rather serious when your "new guard" get mildly trolled. Calm the farm peeps. Happy to give hugs to those that can only dish it but not take. I'm not that big mean and scary.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
