Wrong!! In a number of ways. Twin pods are popular but on my RB25DETT in the track car I ran single AFM and single pod, however the stock GTR setup is single airbox and is good enough for my 260rwkw/0-100 in 4.02s.
I did realise that twin setups can be run off a single filter, but AnjoO was aksing about having multiple pods for a single setup - which IMO is pointless, the only real time when having multiple intakes would have a potential benefit is in a twin system.
  • Replies 94
Posted Images
If you want the loudest pod, the HKS one is the go.
I have one and the induction noise is huge - pity it's one of the worst filters! :D
But then again my pod is shielded so I'm not worried about that. Get a pod and you should always pair it with a box or shield.
i have a apexi pod on my r33 and to be honest after 8 months of driving the car im sick of the induction noise.i have brought a standed airbox and will be putting that on to see if that shuts it up some . the car came with the pod and i have brought the standed box since with a good pannel filter i dont expect to drop power just lose some of the noise i hope
cheers
Heres an idea,....
Get a microphone and mount it under your hood near the STANDARD EFFICIENT and LEGAL filter box
and amplify it through your stereo system so you can deafen yourself and impress all the 14 yo schoolboys waiting for the bus in your area.
SK I think your right!
Yeh well the pod selection is easy the next problem would be heatshielding. All good too put on a pod filter but if its sucking in hot air then can anyone say detonation!! especially on those lovely 40 degree plus australian summers.
man, get the apexi kit from greenline or nengun (check to see which is cheaper)
I got the twin pods on my gtr and they are loud enuff, and as you saw on the website test, the filter the best too.
steve
the noise on a twin setup on a rb26 is much quiter than a single pod on an rb25
PS, I put this thread up there in my Top 20 worst ever questions
LOL sk!
Anyway - I have a LOUD K&N pod filter. I hate it, its too loud.
Anyway I have a custom heatshield, it fits R33. If you want it offer me $50plus $10 postage
Reason for sale - I now have a proper CAI box, from Maxx.
I also have a standard R33 airbox (no snorkel) with brand new B&N panel filter for $100 plus post if anyone is intrested.
Brendan
Edited by Tangles
to make a pod legal (in qld anyway) all you need is a fixed mount for it, for example a bar than comes from the adapter plate to one of the stock airbox mounts.
i have a front mount and can't run the stock airbox as i can't use the snorkel, so the airbox just sucks hot air, but i have a cold ait feed to the pod from the front bar, up through the empty intercooler hole.
having the pod partioned is only good if you have a feed to it. if you just have it partitioned off with no air feed to it then you will lose power.
i plugged the recirulation hole in the stock bov and that cut down a slight bit of induction noise. if you want a pod with minimal noise go for a k&n with the power intake top (the flat top one). i have had one before on my 180sx and it made no induction noise, and i'm veen in a skyline that had one with no noise, but it did have a slight partition. i will have to ask him if he has nosie now that he has put a hks filter on to see if is just the partition.
Well it turns out it WASNT a direct bolt on and i neee some bs adapter now...mmmmmmmmmmm....maybe i bought the wrong pod?
heres the one i got can someone tell me if i got the right one.
Pod Filter
Edited by anjoO
Pod Filter
thats the one
it should bolt on
was it suppose to come with a adapter? cuz i was putting it on but none of the bolts lined up...it needs a adapter........and me being asian i tried putting it on every dodgy way i could think of....and it still didnt work......so u defiently know its not a direct bolt on hahhahahah
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
