It seemed wierd to me - but I would doubt that the alternator wasn't up to it. I can't think how much a pair of headlights uses, but it won't be that much compared to the difference in, say, fan settings between 1 and 4, having you AC on or not, etc. Lights use stuff all compared to them. Is there some regulation in Japan against having double headlights?
I've always preferred the double headlight look. So if your mate invents a thingymawotsit, I would be interested too - I am assuming he knows what he is doing?
Cheers.
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-212854
Just looking at the headlight wiring on my R32. It sure looks like it could benefit from some relays and thicker wires. I doubt it would be safe to increase bulb wattage without doing so. If you run a heavy wire from the battery to the relay don't forget to put in a fuse or circuit breaker. It shouldn't be too hard to wire the lights to work together and upgrade the wiring at the same time. It should make a huge difference.
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-214681
I just noticed this happens, last Monday on the GOR cruise, as i wanted to take a photo with all my lights on.
Just thinking about it, it should not be too difficult. You need a 12V relay, a fuse and a soldiering iron. Just off head, if you were to use the wire from your hi-beams as an input trigger to your relay. Then from the output of the relay tap into the wires going to your low-beams this should work. I would need to find out if the wiring is +ve or -ve trigger.
I will try it on the weekend and let you know.
If my idea is completly wrong and is going to cause trouble please let me know, as i think it might work.
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-214709
It sounds to me like a relay set up is the way to go. I would be surprised it there weren't existing relays in the headlight wiring as it is. It should then be just a matter of connecting the two relays, but I would have to see the wiring diagram (but not being a sparky, I wouldn't set too much store on my opinion!!). Still trying to digest the wiring diagrams from Megala's site ....
I also agree with Majanal, that if you are fiddling around with the lights and wiring, you could take the opporunity to upgrade to Halogen bulbs, even the new high intensity type. Can you get the sexy blue ones for Skylines?
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-216284
Hey All
just a quick word of caution, check how much you are drawing from the battery before you make this mod permanent. The alternator isnt designed to run 4 headlamps at best, and if you factor in amps, ECUs and anything else you may be running, it could lead to a very flat battery very quickly.
My 2c
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-237892
I have the OptiBlue HID globes in my R33. My dip beam still isn't anywhere near bright enough! Does anyone have any sugestions? Would getting the exterior lenses all cleaned up make a big difference? Does anyone know anywhere in Sydney that does this and could reseal the lights? Mine leak too!
https://www.sau.com.au/forums/topic/11959-headlights/#findComment-242754
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
