more pix of mine and kezas skyline.
kezz u havint seen these yet hope u like. ya new mags look good and set the car off relly well.
thanks to every one for puting up there pix of there R32s we all no that thay are the best out of all the lines its been a better turn out then i thort thanks agane
is that a 180 with a 32 front end :) ???
yeah it is (hence 1 and a half R32's :D)... first 180sx in australia with an R32 GTR front. There's another one in SA now tho.
as for the gold R32... it is a chopped photo... the only thing that was chopped was the ride height, the rest is all as it is.
new R32 (yet to ahve bodykit and stuff put on) at a recent track day... on the track...
and off the track (thanks to a tyre coming off the rim)...
I bought this black but i got sick of seeing them around. I no it needs rims badly, they are on there way.
tried these rims but the didnt fit, too wide at the front
without the spoiler, dunno what i like better yet
Edited by play r 32
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
