R32 Pix Only
By SeanR32GtSt · Posted
The rod I was moving left and right you can see looking from the passenger side floor up into the center console. IMG_8095.mov -
Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit. -
Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
