nice car patto, i like your choice of rims... (look above!)
Yeah they are great rims hey! They got the race look but aren't too over the top. Nice and simple. If only they had some dish!
bastard, those shots R HOT !
very nice shots, patto!
Thankyou for your comments guys, I appreciate it.
my 32 at the last round of the Tasmanian Super Series, Baskerville Raceway
Any old GTR can beat a GT3!... try my GTSt beating a GT3 Cup Car!!
Yeah but to be fair Benno the 20's love to rev compared to the big heavy motor in the Porsche :)
Pity Rodders doesn't give that 26 of his a flogging like it should, i think he should slip the front shaft out and join us at the next drift day :)
Nice pics everyone else, keep em coming.
I would put a few up of my car but it makes me sad to look at it sitting in the backyard knowing that it has a popped motor :D
GMB
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
