hooray car is lowered!
I think its down to 340mm
Worried about the front as i have a feeling they might hit the lip if i turn wheel and hit a bump.. ^^,
Now i need to fit on the typeM skits/rear pods + spoiler and it will be all good :P
before:
and after!!!
rolling i can deal with, but not really keen on flarring..
Can you post a pic of a closer look at the flarring?
Also how low is your car from centre to wheel arch?
I think my shocks will drop the height to 340mm and hope i wont need to flare..
Thanks
oi i rekon those URAS's were perfect offset and size for the rear, looks real tough, u can either play around with the rear camber to slip them under or get the guards rolled, although i have to say, i didnt have any issues with mine before i rolled my gaurds, im running around -1 degree of camber. u definitely wont need flaring.
this is mine when i had those wheels before Rekin (17x8/9 +30):
now with some modenas which are soon to be sold aswell (17x8.5/9.5 +45/+38, fronts with 25mm spacers):
next on my list will be something around the 17x9 +20 mark which will sit out another 10mm at the rear from both of those rear wheels and a few mm further than where those fronts are sitting in the 2nd pic.
340mm is best height for r32 in terms of handling. Refer to sydneykid's posts etc for detailed information :whistling:
yep spot on, mine in those pics is the recommended height, using SK's GB kit.
yep I got SK's whiteline set up too
Just took car for drive, mine are scrubbing bad at front.
Any dips in the road and then you hear a creeking noise coming from the fronts.
Not sure if its scrubbing or perhaps the springs/shocks? as it seems to only come from the front right?
Guess its rolling lip on the weekend ~_~
Bummer dude, take the front wheels off and see if there is any damage on the tyres or body both inner and outer, i know that on a certian amount of lock my wheels touch the side skirts, on full they just tap the inner metals and over crazy massive bumps they might just tap the plastic under the guard... but ive got crazy stiff coilovers :(
Hey Rekin, I think your problem could be something to do with your shocks mate. Did you purchase second hand shocks and springs or new?
2nd hand kyb shocks with 2nd hand hks springs.
Perhaps i should get a suspension check done at Pedders?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
