My rig as it sits currently... begging to be dropped:
Lovin the TE37's - but they're a bitch to keep clean. Damn bendix ultimates :)
same as me.. but mine are bronze so its a bit easier to keep em clean.. and ive got bendix ultimates as well.. damn dust
that look very very low!! any problems driving around?
nice one mate!
Besides the fact it scrapes up the driveway in that picture, and cant get over ANY speed bump in Victoria..
Nup! No issues at all lollllllllll... :)
But I wouldn't have it any other way.. :mellow:
Thanks,
Abu
Edited by abu
nice one mate!
Nice looking car man. What coilovers are you running and how stiff are they. Are your rims the 18/8.5+35 front and 18/9.5+38 rear? If so they are the same as mine, very cool.
Thanks man.
I am running TEIN Flex coilover's, and there fairly stiff at the front, but when I slide it hard with someone in the back the rear tires touch the arch a little.
I haven't stiffened the rear ones up yet though, there running low damper but will do it this weekend.
Ride's awesome though, really happy with the ride.
Nah my rims are 17" man, but if you ever want to sell your 18's let me know as I am keep to go to 18's. :D
Thanks,
Abu
Edited by abu
Just took car for drive, mine are scrubbing bad at front.
Any dips in the road and then you hear a creeking noise coming from the fronts.
Not sure if its scrubbing or perhaps the springs/shocks? as it seems to only come from the front right?
Guess its rolling lip on the weekend ~_~
think somethings wrong there mate, definitely shouldnt be scraping like that, so yeh could be shocks or something, i was running the rears on the front which are 9" +30 (which is another 12mm further out then the 8"s) and i didnt have any issue with scraping even then, although it was very close.
Nup! No issues at all lollllllllll... :(
But I wouldn't have it any other way.. :)
Thanks,
Abu
How low is that sitting man?
Coilovers? chopped springs?
nice bro
I agree with everyone else. That 32 sits awesome mate. Id love to go that low but on my coilovers its bumpy as fark! Its also probably one of the first cars iv liked 3 spoke wheels on. Looks decent :rofl:
Thanks man!
Totally agree with you there on the tri spokes lol
Thanks,
Abu
i think its just my shock/spring setup.
The stiffness isnt that much different from stock, so its a comfortable ride but dips in road it scrubs a little.
It isnt that low as you can see :S
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
