LOL
but I bet my offsets, widths and sizes are better
Paint them black then put them on! I'm tempting to paint them black, I reckon it will look tuff on silver
i must be told wat rims these are??
post-51411-1215678172_thumb.jpgpost-51411-1215678236_thumb.jpgpost-51411-1215678272_thumb.jpg
this is my new baby just waiting on turbo and high rise to arrive for a bit more power.
Im pretty bored so i just thought id put some pics up
The difference between standard boring wheels n nice exciting wheels
travis to tell you the truth i really like the way your car looks with the standard r32 gtr wheels, doesnt look boring at all but your wheels look pretty good aswell mate, do you mind me asking how much you picked up your wheels for,
cheers tony
cheers tony
yeh it looked good when it was clean with the tiny wheels on but once it gets dirty they make the car look really bad ay
lol jetgtr thats exacely what i said, if they were 18s i would piss any wheel off and go for them and abu your getting everyone jealous mate so just stop showing your car off hehe, guys we should organise a cruise with all our skylines sometimes and if yous want on september 12th wer all going to calder park to run our acrs so anyone just pm me if they are intersted in comeing along and having some fun,
cheers tony
yep Uras NS-01's
17x8 front 7 17x9 on rear
+30 offset
Too many times people refer to them as drifteks :)
are these the same one you get through just jap?
im thinking of getting a set to put the semi slicks on for the track, are they any good?
they're hot i like em...pm sent rekin
hehe pm replied
yes they are exactly the same as the ones Justjap sells, although ive heard that they have run out of stock of 9inch wide and only have 8inch available
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
